Author Topic: Hot & Cold!!  (Read 833 times)
Hot & Cold!!
« on: 18 April 2009, 18:46:24 »
Hi all, I drove my 2002 2.2CDX Auto (petrol) home from the place I bought it on Friday, & being a cold day I put the climate control on ECO with the setting at 22deg. The passenger side worked great, lots of lovely hot air, but the drivers side was Bl**dy freezing! It makes no difference on what setting or temperature I have it on, it is hot on one side & cold on tother! Any suggestions? Kind Regards, Phil. :-?
Re: Hot & Cold!!
« Reply #1 on: 18 April 2009, 19:07:11 »
Arm come off motor. Have a look here, details passenger side but same driver`s side http://www.omegaowners.com/forum/YaBB.pl?num=1196616207
Re: Hot & Cold!!
« Reply #2 on: 18 April 2009, 20:23:02 »
Many Thanks RobG, that sounds exactly what I need! I will try it ASAP & let you know how I get on. Kind Regards, Phil. :y
Pete Elite
  • Uxbridge, Middlesex
Re: Hot & Cold!!
« Reply #3 on: 19 April 2009, 01:10:17 »
Hi Phil,
         Please let me know if you sort this problem as it is exactly the same problem I've got on my pre-facelift :(.
                  Cheers,
                            Pete :y.
Re: Hot & Cold!!
« Reply #4 on: 26 April 2009, 16:17:55 »
 :) Hi all!
Well, I finally got round to fixing my Hot&Cold problem. The 'Howto' on refitting the plastic actuating arm was 'Spot On'. Heartfelt Thanks to RobG for pointing me in the right direction and Bales1963 for your great 'How to' and also to everyone else who contributed. You lot are the 'Bees Knees' :y :y :y Kind Regards to you all, Phil.
