Author Topic: Sluggish acceleration  (Read 1178 times)
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« on: 26 April 2009, 15:04:29 »
Hi All,
I am just in the process of running some injector cleaner through my tank to see if my injectors are bunged up, whilst giving the car a blast down the bypass i noticed it was a bit sluggish accelerating even in sports mode, seems as though it takes a moment to wind up to speed. is that symptomatic of the transmission fluid wanting topping up or something else??
Omega 2.6 V6 Elite in Shiny Black
ians
  • Reading
Re: Sluggish acceleration
« Reply #1 on: 27 April 2009, 10:53:28 »
might be worth doing the standard 4 pot ICV, throttle body, breather clean - that generally makes a world of a difference to how the thing runs.
mark.adams
  • Cambridgeshire
  • Happy
« Reply #2 on: 27 April 2009, 13:27:42 »
Thanks,
Did that recently when we changed the HG, all breathers, butterfly valve and idle pinhole valve, new exhaust manifold gasket too.
I was just curious if that was the symptoms i would see if the transmission fluid needed topping up, its never been topped up as far as i know.
ians
  • Reading
« Reply #3 on: 27 April 2009, 14:11:55 »
Well wouldn't do any harm of course (and if its low, obviously it would do a lot of good anyway), but I'm doubtful that's the cause of the problem.
« Reply #4 on: 27 April 2009, 14:14:14 »
2.2 does not have an ICV.
Check the box fluid level, should be up to the fill hole with engine running on flat surface
