Author Topic: Help EML Just come on!  (Read 3213 times)
richardirv
  • Leeds, West Yorkshire
    • Omega 2.6 MV6 2002
« on: 26 April 2009, 14:39:18 »
I have just done the pedal trick, code was 10 1 10 10 which is 0100 i assume. Can someone tell me what that means please?
Cheers
Edit: Just been searching and it looks like MAF. Can someone confirm this.
I have  a pipercross on and I know it can cause the MAF Sensor to fail. Will putting the standard air box back on help or has the damage been done?
Engine running perfect though!
« Last Edit: 26 April 2009, 14:45:31 by richardirv »
Re: Help EML Just come on!
« Reply #1 on: 26 April 2009, 14:46:39 »
I think once youve contaminated your maf its game over  :'(
about £150 new!
richardirv
« Reply #2 on: 26 April 2009, 14:48:14 »
Bummer, what happens if i leave it, can't afford a new MAF right now
« Reply #3 on: 26 April 2009, 14:48:19 »
Search Results
Search results 10 matches found for Control Valves & Units, Sensors & Flow Meters + Airflow meters
Omega       Part Number       Retail Price       Normal Trade       Trade Club
Airflow meters
2.0 8v                                         90510154       £226.00       £203.40       £176.06
2.0 16v                                         90411957       £137.00       £123.30       £106.40
2.2                                          90530463       £92.50       £83.25       £75.13
2.5/3.0 to ENG 08137540                                      90510156       £236.00       £212.40       £184.11
2.5/3.0 from ENG 08137541                                     90541591       £223.00       £200.70       £173.66
2.6/3.2                                         93171760       £162.00       £145.80       £126.41
2.0DTi                                         93171356       £139.00       £125.21       £108.17
2.2DTi                                         93171355       £112.00       £100.80       £87.00
X25TD                                         90528813       £188.00       £169.20       £146.11
Y25TD                                         93174628       £177.00       £159.30       £137.80
Beleive there are MUCH cheaper options out there!
richardirv
« Reply #4 on: 26 April 2009, 14:58:41 »
Are the ones on  ebay and such around £40 ish a load of rubbish?
« Reply #5 on: 26 April 2009, 15:02:07 »
Sure Mark uses Ebay ones, not sure of any pointers as to what though
richardirv
« Last Edit: 26 April 2009, 15:06:56 by richardirv »
richardirv
« Reply #7 on: 26 April 2009, 15:45:14 »
To buy or not to buy?  :-/
SJKOO01
« Reply #8 on: 26 April 2009, 16:58:21 »
Believe there's a thread on here on how to clean the MAF sensor. Its based on a Granada Scorpio one, though I think the principle maybe the same. Maybe worth looking through the OOF forum to find it.
Or you could try locating one on through OOF parts section, or ebay, or even breakers yard if you have one close ? - Just an idea ??.
M
richardirv
« Reply #9 on: 26 April 2009, 17:02:32 »
I have just had it all off and  put the standard air box back on, still EML is on, MAF looked spotless but I will have a look on what to clean although as I said it looks brand new.
« Reply #10 on: 26 April 2009, 17:03:51 »
its the oil knackers em, maybe could dismantle and burn it off?
anyway, its sunday, so get more opinions before jumping in to buy a new one.
richardirv
« Reply #11 on: 26 April 2009, 17:07:33 »
Yeah not gonna order one just yet, One thing to mention is that i never oiled the Pipercross, just choose to clean it frequently, So oil shouldn't be a problem.
« Reply #12 on: 26 April 2009, 17:08:20 »
ahhh maybe a red herring then, its the oil on oiled filters that does the damage
richardirv
« Reply #13 on: 26 April 2009, 17:12:49 »
Wierd eh, well its back to standard now, fingers crossed it may fix its self, doubt it though.  :'(
Just hope I read the code correctly with the pedal trick.
« Reply #14 on: 26 April 2009, 17:16:07 »
bizarrely I suspect the MAF on hers wasnt right, swapped it with mine for a test, and now both are running fine!  so maybe the connector wasnt right, I didnt have any codes though.
Page created in 0.038 seconds with 20 queries.
