Author Topic: check oil level  (Read 1225 times)
aymen
  • syria
check oil level
« on: 28 April 2009, 08:03:04 »
dears,
can you help me about the symptom of a clause appears on display of my omega 2.2 says "check oil level"
what does it mean and what may the reason be?
thanks
aymen
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: check oil level
« Reply #1 on: 28 April 2009, 08:05:31 »
dears,
thanks
aymen
As the warning says really, check your oil level and top up if neccessary :y
Trade club card holder
Code scanner available
Richard A
  • Aldridge, West Midlands
Re: check oil level
« Reply #2 on: 28 April 2009, 09:54:27 »
GM say 'allow 5 minintes' after engine has been switched off, then check dip stick. Always keep the oil level up to the maximum. Long uphill stretches on motorways can cause the oil to flow to the back of the sump ie away from the 'oil sensor'.
regards
richarda
richard a
Omegadoha, Desert Member
  • Doha, Qatar
Re: check oil level
« Reply #3 on: 28 April 2009, 10:26:01 »
It could be that your oil level sensor needs replacing. But obviously check oil levels first.
omega rick
  • witham essex
Re: check oil level
« Reply #4 on: 28 April 2009, 14:08:16 »
my o my , I know we are all out there to help each other but !!!!!!!!!!!!¬
Re: check oil level
« Reply #5 on: 28 April 2009, 19:26:20 »
dears,
thanks
aymen
You can get this if the oil level is around 1/2 between min and max, so keep level in upper half.
Could also be a switch failure, more common if the car has a poor oil service history.
