Author Topic: uprated fuel pressure regulator  (Read 1186 times)
omegav6est
  • corsham wiltshire
« on: 30 April 2009, 15:47:40 »
hi all has anybody any experiance of one of these.just wandered if might get a bit of extra oomph. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=390032089965f.thanks
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: uprated fuel pressure regulator
« Reply #1 on: 30 April 2009, 15:57:45 »
Wouldn't have thought an increase in fuel pressure would make any difference at all without an increase of more air and fuel in to the pots.
MutantCav
  • Gainsborough
« Reply #2 on: 30 April 2009, 15:59:37 »
Injectors (I think its the injectors) only run to 3.8 Bar so 4.0 bar is pointless...
« Reply #3 on: 30 April 2009, 15:59:49 »
Yep. No point, unless you run out of flow with the current injectors. An engine is not a bonfire. More fuel does not equal more power.
In reality, fitting one of these will simply cause the ECU to trim fuelling back by reducing injector duration so you'll be back where you started.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #4 on: 30 April 2009, 17:19:30 »
to utilise one of these would require £££ bigger injectors for a start and then you need to reprogram the ecu so not worth the hastle
btw you can buy that 4 bar FPR from any Motorquip motorfactors for £22 + vat
omegav6est
  • corsham wiltshire
« Reply #5 on: 30 April 2009, 19:49:49 »
thank you very much for the replies, backs up what i thought really just needed tellin. lol
