Author Topic: Reversing Sensors?  (Read 2315 times)
Reversing Sensors?
« on: 30 April 2009, 20:15:58 »
  :-? Anybody fitted these to a facelift 2.2 Omega?, I have a set in the post to me as I type & haven't a Bl**dy clue where to start! As this is my first Omega & an instant love affair, I didn't realise what a big beast she would turn out to be, especially from behind!!!! :D Any help would be greatly appreciated! Regards, Phil.
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Reversing Sensors?
« Reply #1 on: 30 April 2009, 20:18:42 »
fitted them to my mums 307 CC and all i needed was a 1/2 inch hole cutter drill attachment thing!
peugeot had small drill here points on the inside of the rear bumper aswell  :y dont know if the omega does? i had to take the back bumper of the pug and id guess the omegas would need to come off too
« Reply #2 on: 30 April 2009, 20:19:21 »
Just use the mirrors!!!  :y
Says he, who reversed into a tree on Easter Sunday! :-[ :-[ :-[ ;D ;D
« Reply #3 on: 30 April 2009, 20:23:33 »
 ;) AndyB, I always use mirrors, but only when combing what hair I have left mate!! ;D
omegadti
  • Glasgow
    • omega dti
« Reply #4 on: 30 April 2009, 20:32:21 »
when you suss it please post the solution as I have a 2 sensor kit waiting for me to pluck up the courage to drill my bumper
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #5 on: 30 April 2009, 20:36:03 »
Have fitted them to mine, bumper will have to come off to remove and adapt the foam cushioning which sits behind it :y
« Last Edit: 30 April 2009, 20:39:07 by alexandjen »
Trade club card holder
Code scanner available
« Reply #6 on: 30 April 2009, 20:36:37 »
That's where you're going wrong ...... you should be looking at where you're going in them!!!  :y  :y  :y  :y ;D
jemis
  • Teesside
« Reply #7 on: 30 April 2009, 20:39:49 »
I fitted a set to our facelift estate, it was fairly straight forward really the drill bit needed was in the kit and it came with easy enough to follow instructions.
Find the centre line of the bumper and if I remember rightly mearsure 20cm each side for the first 2 holes and then 40cm past each of them for the outer 2 I measured them 50mm up from the line in the bumper, I will put up a pic tommorrow for you.
The wiring is a doddle as it all just plugs into to the unit after taking a live from your nearest side reverse light.
Hope this helps.
old git
  • Shrewsbury
« Reply #8 on: 30 April 2009, 21:55:03 »
My inboard sensors are about 32 cm from the centre of the bumper ,I have a fixed tow bar and they don't detect that sticking out ,outboard about 64cm.I did check by placing an obstruction where the bar would be before using a fixed bar.they will take car to within 14cm of obstruction .Sh** forgot tow bar again
old git
  • Shrewsbury
« Reply #9 on: 30 April 2009, 22:01:34 »
about 5 cm down from bumper line (facelift)
« Reply #10 on: 01 May 2009, 09:19:07 »
 :-/ Thanks everyone! but just to show how really stupid I am, can you tell me what colour wires I need to connect into? I can find my way around a domestic 3 pin plug at home but car wiring is another kettle of fish! :y Regards, Phil.
