Author Topic: Now its Radiator Fan...  (Read 1133 times)
going crazy
  • Middlesex
« on: 01 May 2009, 16:09:28 »
All,
I am back with more problems :-( :'(
Nice hot sunny day and I got stuck in traffic, noticed the engine temparature reached above 100 and the fan did not kick in
When I came back the coolant was boiling and a little spilled out of the overflow tank.
I have recently replaced the radiator and the fan switch - should I replace the Fan or check for thermostat or something.
The GM spare part number on the fan is 90448148 - any one has a spare?
Thanks
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Now its Radiator Fan...
« Reply #1 on: 01 May 2009, 16:15:08 »
if you had boiling water in your expansion tank then check your Headgasket!
there is a fuse on the V6's that some times blows it lives in the engine bay fusebox by the battery if it fuses on a V6 the fan stops working dont know if the 4 pot is the same though....
« Last Edit: 01 May 2009, 16:15:28 by tmx »
