Author Topic: How do I read fault codes on my omega + identify?  (Read 1544 times)
jampot1979
  • stevenage, hertfordshire
« on: 01 May 2009, 20:06:46 »
Been searching on here on how to read the fault codes on my 2002 omega. I havent had much luck finding the guide. Also once I find the codes, is there a chart on here to tell me what they mean?
Many thanks
James
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: How do I read fault codes on my omega + identify?
« Reply #1 on: 01 May 2009, 20:07:41 »
try searching the pedal trick ;)
« Reply #2 on: 01 May 2009, 20:12:25 »
alas not on the 2.2. Neither the pedal trick or paper clip test will work on that engine. You need a code reader, tech 2 is most comprehensive, or one of the other much cheaper options.
« Last Edit: 01 May 2009, 20:13:23 by chrisgixer »
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #3 on: 01 May 2009, 20:17:08 »
if you tell us your location there  maybe a Tech II Equipped member near you or a  OBD 2 Code reader equiped member
they will be able to save you alot on garage diagnostic bills!
« Reply #4 on: 01 May 2009, 20:17:26 »
Many thanks
James
Fill in your profile with your rough location and we may be able to direct you to a tech2 owning member on here.
Edit
Hehe... Snap. :-)
« Last Edit: 01 May 2009, 20:19:58 by chrisgixer »
jampot1979
« Reply #5 on: 01 May 2009, 20:41:41 »
I am located in stevenage, hertfordshire. Cheers for ya help! :)
