Author Topic: paint  (Read 3116 times)
000jonboy
  • exeter
paint
« on: 29 April 2009, 22:56:17 »
hi everyone just a quicky question what is the best way to remove overspray haad my car fixed not long ago and it is covered in whiteish paint (and mine is black) ive had a quick go at it with compound and it takes ages wont take it back to garage coz they trashed my car and it woz mint condition before   :-/ :-/ :(
Bent valve
Re: paint
« Reply #1 on: 29 April 2009, 23:05:39 »
Nail varnish remover or acetone will shift it, but be carefull not to use too much or rub to hard as it may damage your paint finish. try a bit on the inside of your boot lid or somewhere it wont show first if in doubt
000jonboy
  • exeter
Re: paint
« Reply #2 on: 29 April 2009, 23:10:38 »
i'll try that  coz the compond seemed like too much hard work  ::)
unlucky mark mv6
  • tipton,west mids
Re: paint
« Reply #3 on: 30 April 2009, 12:36:34 »
2000 wet and dry,compound then mop it after with electric 2 speed mop.Shame your not nearer cause i have one you could have borrowed or i could have done it for you.
Re: paint
« Reply #4 on: 30 April 2009, 13:23:40 »
agreed...but if you are not patient use 1500.. nothing different and no chemicals except polish paste.. :-?
000jonboy
  • exeter
Re: paint
« Reply #5 on: 01 May 2009, 17:12:20 »
thanks guys but the only thing what worys me is that wont the wet and dry scratch the laquar :-/
Re: paint
« Reply #6 on: 01 May 2009, 20:10:42 »
2000 grid wet wont harm..of course it depends on how long you will use..
Better get some help from an experienced friend on application..
after you can correct with G3 :y
holtender
  • Suffolk
    • 2.5 CDX Facelift
Re: paint
« Reply #7 on: 01 May 2009, 22:04:14 »
Put some Fairy liquid in a bucket of water to use with the wet and dry paper, with the flat of your hand, just gently remove the surface of the lacquer it will turn white.
 Dry off and then use rubbing compound to bring back the shine, finish up with t-cut.
Miggy24
  • Exeter,Devon
Re: paint
« Reply #8 on: 02 May 2009, 08:24:02 »
Just G3 it and will all be good
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: paint
« Reply #9 on: 02 May 2009, 17:48:05 »
Nothing against wet and dry lads but personaly I would use T-cut even if it takes a few times. But it should come off with a couple of T-cuts, if its only a mist covering. or if you can get your hands on any try the German Lack rieniger (Car paint cleaner) its also good stuff. ;)
He who brakes Looses
To old to die young
