Author Topic: Vibration at 55+Mph  (Read 1909 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Vibration at 55+Mph
« on: 03 May 2009, 18:59:18 »
Hi all .... as above im getting a vibration through the car at 55 mph and above , it doesnt appear to be coming from the front as im not getting a steering wheel wobble that bad ... i am getting a very slight wheel wobble in the front but im thinking more the rears as the vibration feels like its coming through the car and not the steering . Im going to get my wheel balance checked to see if thats the cause on wednesday as its my first day off and i may do the front discs anyway and i am getting very slight wobble on braking . I called my local tyre place on saturday which used to be called Budget but to my suprise its been taken over by Kwik Shi*  :-/ :-/... when i explained the symptoms he said front anti roll bar bushes without even looking at the car , i wasnt to impressed .. anything else i should be looking at if its not the wheel balance  :-/
Cheers
Re: Vibration at 55+Mph
« Reply #1 on: 03 May 2009, 19:44:29 »
wobble in the wheel = front
wobble in the arse = rears
 ;D ;D
I had vibration around the same speed, pop along to WIM, get the treatment  :y
« Reply #2 on: 03 May 2009, 19:44:52 »
oh, just seen where you are, hummm bit of a haul for you  :'(
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #3 on: 03 May 2009, 19:48:21 »
Have a look at you Drive shaft c if the uni joint is ok nothing broken or missing just to be sure. I had it once on a artic truck was told it could flip the truck over if it does go. its possible it has nothing to do with your problem but at least you know its ok. ;)
He who brakes Looses
To old to die young
Proz
« Reply #4 on: 03 May 2009, 20:26:52 »
 Yeah a bit of a trip  :y :y
« Reply #5 on: 03 May 2009, 21:13:06 »
Can always make it a bit of holiday!  ;D
I can't recommend WIM enough, i had vibration braking from 65 down to 50 ish and at 80 ish had it in the wheel and seat.
WIM transformed it! Tracks so smooth and straight as an arrow, goes around corners like its on rails.
« Last Edit: 03 May 2009, 21:13:32 by tunnie »
omega6
  • Midlands
« Reply #6 on: 03 May 2009, 21:18:14 »
I HAD EXACTLY SAME PROB, VIBRATION NOT THRU STEERING WHEELS JUST WHOLE CAR SHAKED, THOUGHT IT MAY BE GEARBOX MOUNTING, AS EXCESS GEAR STICK SHAKE, TOOK CAR TO GET WHEELS BALANCED, TURNED OUT TO BE DISTORTED REAR TYRES
Proz
« Reply #7 on: 03 May 2009, 21:27:19 »
I dont have gearstick shake so hopefully not anything like gearbox mountings .... im hoping ive just lost some balance weights and a rebalance will sort it  :-/
Proz
« Reply #8 on: 03 May 2009, 22:11:54 »
I hope i dont have a bent wheel ..... i cant remember hitting any potholes .... been doing it for a wee while but only today i noticed it badly as i was on motorways , havn't been up to motorway speeds for a while  :'(
