Author Topic: 2001my 2.2DTi quicky...  (Read 1378 times)
Welung666
« on: 04 May 2009, 13:42:15 »
Are these timing chains or belts?
Re: 2001my 2.2DTi quicky...
« Reply #1 on: 04 May 2009, 13:47:34 »
guessing franky, but as its based on the petrol 4 pot i would say belt. GUESSING mind....
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #2 on: 04 May 2009, 13:52:55 »
Chain. vectra 2.2 ecotec dti is and im sure the omega has the same lump for its dti engine
« Last Edit: 04 May 2009, 13:53:45 by tmx »
Welung666
« Reply #3 on: 04 May 2009, 14:30:44 »
So top and bottom off for head gasket then?
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #4 on: 04 May 2009, 14:31:57 »
is it forsale as a non starter?
Welung666
« Reply #5 on: 04 May 2009, 14:36:30 »
its been used every day on the motorway till one day black smoke came out from the engine
 :D :o
« Last Edit: 04 May 2009, 14:38:09 by Welung666 »
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #6 on: 04 May 2009, 14:53:03 »
If it wont run dont buy these engines suffer badly from failed injector pumps very very expensive to put right!
next door had a 2.2DTi vectra that blew loads of black smoke and then cut out turned out his injector pump had gone
Welung666
« Reply #7 on: 04 May 2009, 14:57:28 »
Half tempted to break it, I could do with a couple of the panels ;D
