Author Topic: rocker cover bolts.  (Read 929 times)
unlucky mark mv6
  • tipton,west mids
rocker cover bolts.
« on: 04 May 2009, 15:15:41 »
I have oil seeping from a couple of the rocker cover bolts on my 3.2.Can you replace the rubber o-rings which im led to believe it is,and do you have to strip everything,or just take the bolt out.
Bent valve
Re: rocker cover bolts.
« Reply #1 on: 04 May 2009, 15:26:45 »
 The o rings are under the cover. you would have to remove them which would also mean replacing the gaskets.
« Reply #2 on: 04 May 2009, 15:29:11 »
try re torquing to 8nm (not a penny more mind) i had a couple weep and they where loose. Do NOT over tighten.
There is a guide in maintenance re cam cover gaskit and o poing replacment. It involves removing plenum etc.
