Author Topic: V6 Exhausts Centre Section Fitment  (Read 3488 times)
tmx
  • Herefordshire
    • 3.2 MV6 2002
« on: 30 April 2009, 19:43:59 »
well ive finally got the time to fit the Meegas silencers ive noticed however that vauxhall in there excellent wisdom have threaded the Cats!
so the centre section flange bolts onto the threaded cat side very bad design  >:(
anyone know a good way to get them off i know these bolts are gonna be a rite PITA
i dont have a Gas torch so gas isnt an option :(
MutantCav
  • Gainsborough
Re: V6 Exhausts Centre Section Fitment
« Reply #1 on: 30 April 2009, 19:47:01 »
Just plus gas them for a few days before :y
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #2 on: 30 April 2009, 20:01:50 »
WD40s similar? ive got loads of that ill spray the bolts up in abit! so they will actually come off then?
« Reply #3 on: 30 April 2009, 20:09:17 »
I sheared a couple of mine & had to re-drill & tap them. Perhaps you could try a local tyre bay when they're quiet and ask them to use a bit of oxycetlene!  :-/
Welung666
« Reply #4 on: 30 April 2009, 20:11:06 »
No it isn't! WD40 is shite water displacer, PlusGas is proper penetration fluid. 2 or 3 shots a day for a couple of days will see you right :y
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #5 on: 30 April 2009, 20:13:10 »
PlusGas it is then ill pop to the local motor factors tomorrow then :) thanks for the advice
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #6 on: 30 April 2009, 22:34:36 »
deffo use Plusgas Tom it's the nuts :y
i think they even sell it in halfrauds ;)
« Reply #7 on: 01 May 2009, 00:01:28 »
Mine comes free of charge from stores!!  :y  :y  :y  :y
Pete Elite
  • Uxbridge, Middlesex
« Reply #8 on: 01 May 2009, 00:07:35 »
     So Andy your a shoplifter then :o :D ;D ;D ;D.
« Reply #9 on: 01 May 2009, 00:25:47 »
Not THAT kind of stores  ;D  ..... engineer's stores at work!!!  :y  :y  :y
You're allowed to book out £££££££££££££'s of expensive bits & pieces, but you still need a managers signature for batteries & other 'attractive consumables' ....   ;)  ;)  ;)  ;)
Pete Elite
« Reply #10 on: 01 May 2009, 00:28:41 »
      Ah right Andy i see, so your a forger as well :D ;D ;D ;D.
« Reply #11 on: 01 May 2009, 00:36:11 »
Just what kind of bloke do you take me for? I'm an upstanding member of society! .... generally  ;D  ;D  ;D  ;D
Pete Elite
« Reply #12 on: 01 May 2009, 01:20:01 »
    So let me get this straight Andy, your not only a shoplifter and a forger but you generally like going about in society with your member upstanding, well i never :o :D :D ;D ;D ;D.
« Reply #13 on: 01 May 2009, 01:22:39 »
er! .......  :-X  :-X  :-X  :-X
They do say that when you're in a hole ..... stop digging!  ;D  ;D  ;D
Pete Elite
« Reply #14 on: 01 May 2009, 01:27:06 »
          ;D ;D ;D ;D ;D ;D ;D.
Page created in 0.038 seconds with 16 queries.
