Author Topic: Engine coolant temp sensor and p0115  (Read 972 times)
estaszew
  • USA, Long Beach, California
« on: 04 May 2009, 22:11:16 »
I have had an intermittent p0115 code (engine coolant temp sensor or harness).  Does anyone have an easy way to access the sensor and harness at the back of the engine.  I removed the scuttle, but it didn't seem to be enough.  Would I have to remove the plenum too, or is there more.  Thanks in advance!
Re: Engine coolant temp sensor and p0115
« Reply #1 on: 04 May 2009, 22:49:38 »
plenum off. Bit of a pain for a simple spade connector to a nipple on coolent bridge, unless its the sensor itself of course.
 You may well think, once you see it, it could be done by feel but too much gubbins in the way.
