Author Topic: anyone made a pressure test cap?  (Read 2302 times)
kingplym
  • camden, hatfield, st.neots
  • sports on, kick down
« on: 05 May 2009, 17:08:07 »
as above has anyone made a pressure test cap as i seem to be slowley losing coolant.  i had a massive coolant loss, a one off, just before the oil cooler went and now seem to be losing coolant. :-?
i know it might be hbv, but if anyone has made one can i borrow it ;)
or if one of the miggy breakers is reading or anyone else, has anyone got a spare cap laying around i could have and convert myself ;) :y
i am willing to trade my electrical labour for parts work etc
Re: anyone made a pressure test cap?
« Reply #1 on: 05 May 2009, 17:10:10 »
I knew there was something I should have picked up at the scrap yard the other day!!  ;D  ;D  ;D
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #2 on: 05 May 2009, 17:12:07 »
my car lost loads of water when the HBV went it even left a drip trail!
it just went suddenly too! over the course of a few days
kingplym
« Reply #3 on: 05 May 2009, 17:12:35 »
does anyone know of any scrap yards in hertfordshire all the ones i used to know have gone :-?
kingplym
« Reply #4 on: 05 May 2009, 17:13:58 »
that the thing thou tmx, i had a massive loss an now just a steady loss of about a litre a day :(
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #5 on: 05 May 2009, 17:16:41 »
this should help greatly
the expansion tank cap on the omega is the same as a vectra B loads and loads of them in scrappers!
kingplym
« Reply #6 on: 05 May 2009, 18:13:17 »
i just dont know where a scrappie is anymore :-[
MutantCav
  • Gainsborough
« Reply #7 on: 05 May 2009, 19:33:23 »
Pretty sure I have a spare one floating around that I can send with those cams if you want them :y
over50now
  • Hertfordshire
« Reply #8 on: 05 May 2009, 19:38:55 »
Scrappy at Letty Green, just outside WGC.    A414 Hatfield to Hertford.  Roundabout where troppical fish is turn right.
If you turn left, takes you to the back of Panshanger and towards Tewin  (LH country)
Hope you know where it is.
Also try Barton Scrappies.  Near Barton Ley Clay, just north of Luton
IAM & ROSPA Gold Grade driver
Richard A
  • Aldridge, West Midlands
« Reply #9 on: 05 May 2009, 19:41:31 »
Hello there 'kingplyn' I have a spare, send me a 'pm' with your address and I will post it to you tomorrow.
Iv'e had so much help from forum members over recent weeks it's the least I can do.  ;)
regards
richarda
richard a
kingplym
« Reply #10 on: 05 May 2009, 19:42:26 »
cheers over50!!! :y :y :y
big-o-bob
  • Yorkshire
« Reply #11 on: 05 May 2009, 21:48:42 »
Could it be the seal on the oil cooler plate Kingplym? or maybe one of the coolant bridge seals has'nt seated properly when put back together (I have heard of this happening before on here).
Not doubting you're work mate, but as you know, even the most competent people can encounter failed seals.
What would I know though - I still havent managed to get that bloody nut undone on the oil cooler pipes... :D
I had the HBV fail on my last omega, it only leaked when my heater blower was turned on!... on mine anyway.  It did leak fast though.
I must say, it was a lot easier job to change the HBV than the oil cooler is turning out to be mate.
Hope you get sorted.  I'm gonna have another final bash at that nut as soon as the weather holds off a bit. :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #12 on: 05 May 2009, 22:49:59 »
Instead of waiting for the Postman, I assume you are going to convert your old one?  :y
kingplym
« Reply #13 on: 06 May 2009, 08:05:23 »
good luck again with that oil cooler bigobob :y
i was thinking the same as regards having failing seal washers or wether i did seal up the cooler plate properly, as i  had a bit of movement when refitting. that why i was gona go with the home made pressure test.
i had to put two litres of water in me miggy this morn :o
but still using car so cant use old one :-[
thanx all :y :y :y
