Author Topic: start of an oil leak  (Read 2382 times)
portomega
  • Port Talbot, S. Wales
« on: 06 May 2009, 14:19:45 »
Was just having a look around the engine the other night and noticed a slight oil leak from the top of the engine, it appears to be leaking around the passenger side only and then dripping down the back of the engine onto the front of the gear box, what could be the cause of such a leak? :(
Re: start of an oil leak
« Reply #1 on: 06 May 2009, 14:21:17 »
cam cover gasket.
Make sure you keep the breathers clean, if not they block, and cause the cam cover seal to go.
Easy to replace, follow my guide. Only use geniune gaskets:
http://www.omegaowners.com/forum/YaBB.pl?num=1225024176
portomega
« Reply #2 on: 06 May 2009, 14:25:54 »
cheers for the link, but im not really able to do this myself though as im useless when it comes to repairs lol id be too worried about cocking things up
Its due a full service in 1000 miles , is this problem a major thing? could i leave it for a while or does it need to be done straight away, could it cause me more problems if i leave it?
« Reply #3 on: 06 May 2009, 14:29:05 »
It should be done straight away, you need to look at the cause, of the problem as well. Do you clean the breathers?
Its very straight forward to do the gasket as you cans see from the pics, i am useless at cars, and even i could do it.
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #4 on: 06 May 2009, 14:29:36 »
I used to be terrified to touch a car and never owned a spanner but after following guides on here im no longer afraid and will try almost anything ...within reason  ;D :y :y
portomega
« Reply #5 on: 06 May 2009, 14:39:46 »
thats the thing lol i dont own any tools! wait!!! i think i got a screw driver in the boot somewhere  ;D problem now is im working for the next 13 nights, 12 hr shifts, so no real time to take my car to a garage, im sure my car knows when im stuck doing overtime and decides to break itself!
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #6 on: 06 May 2009, 14:44:30 »
if your getting the breathers done by a garage then demand they clean the crankcase breathers
we do have members that offer Mobile Omega Repairs JamesV6CDX & Looknee & Elite Pete try pming them for a quote
But if its done by oofers it will be done properly :y
i done it on a V6 and its not that hard! so a 4pot should be nice and simple!
« Last Edit: 06 May 2009, 14:45:54 by tmx »
Proz
« Reply #7 on: 06 May 2009, 14:45:07 »
I got the Halfords Professional 150 piece toolkit which i belive now is less than £100 and has all the tools i think i would ever need and a code reader diagnostic thing for £40 ... Wouldnt take long for a mechanic to charge £140 in labour  :-/ ..... plus the satisfaction of fixing it yourself  :y :y
« Reply #8 on: 06 May 2009, 14:48:37 »
as above, i have limited tools, but the Halfords 150pc set does it all, wait for it to be on offer for £99, its paid for itself time and time again.
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #9 on: 06 May 2009, 14:49:55 »
£99 on offer i wonder if the halfords trade card will reduce the price even further??
Proz
« Reply #10 on: 06 May 2009, 14:52:49 »
Plus the professional stuff if you break anything in the set they replace it free .... lifetime guarentee  :y
portomega
« Reply #11 on: 06 May 2009, 14:57:04 »
I probably could do it myself but i just dont have the mechanical confidence to do it, id be way too worried about ballsing it up lol
So its the cam cover gaskets that are on the way out? thats not the same as the head gasket is it? because from what ive read on here that going is a magor problem  :(
Proz
« Reply #12 on: 06 May 2009, 14:59:58 »
I was exactly the same ... no confidence at all and scared of making the problem worse ... youll be suprised what you can do following the very good guides on here  :y
« Reply #13 on: 06 May 2009, 15:04:23 »
No, your safe, head gasket is the main metal gasket that is sealed between the 2 big parts of the engine.
Cam cover gasket or rocker cover as it can be known is a rubber gasket that just sits undernearth the plastic ecotech cover, its just those bolts on top, its dead easy  :y
« Reply #14 on: 06 May 2009, 15:04:46 »
Sadly not, trade card has no affect on sale items
