Author Topic: Air con and heater matrix.  (Read 1201 times)
Omegadoha, Desert Member
  • Doha, Qatar
« on: 06 May 2009, 14:57:09 »
Got the A/C regassed today and my Air conditioning appears to have a leak. I took the dust cap off the low pressure valve and it is definately hissing. Also I put my finger on the valve and you can feel a slight pressure.
Is is possible to buy a replacement valve and do you need a considerable number of components?
Answers appreciated as already had two showers today. ;D Its getting like 36 deg C.
Also is the a/c system at all linked to the heater matrix?
KillerWatt
Re: Air con and heater matrix.
« Reply #1 on: 06 May 2009, 15:27:45 »
Did the people who did the re-gas not check it for leaks before they filled it?
  • Doha, Qatar
« Reply #2 on: 06 May 2009, 15:31:08 »
No. He just  diagnosed the heater matrix by looking at the car. But I didn't mind paying 10 quid for immediate relief. :-?
cleggy
« Reply #3 on: 06 May 2009, 15:57:00 »
I had the same problem when mine was regased last week. The valve was leaking, diagnosed by the garage, they ordered a new one, called me when it arrived, fitted it while I waited, regased the system all for a grand cost of £70. I though that was very reasonable when you consider they charged £45 + VAT just for a regas ( which all leaked out!), and it had to be regased after the replacement valve was fitted. I should mention that the car was regased, and only started leaking when the aircon was switched on.
« Last Edit: 06 May 2009, 16:00:22 by cleggy »
  • Doha, Qatar
« Reply #4 on: 06 May 2009, 16:00:32 »
Thanks. Do you know if it was the low pressure one?
« Reply #5 on: 06 May 2009, 16:02:02 »
did they put a dye in with the gas?
cleggy
« Reply #6 on: 06 May 2009, 16:06:58 »
Sorry I don't, the chappie just told me a valve was leaking never thought to ask which one. Not that it would have made any difference if he had told me ( i'm a bit clueless when it comes to mechanical things, to me a valve is a valve any more info and I just get confused)
Page created in 0.239 seconds with 20 queries.
