Author Topic: Coolant?  (Read 1278 times)
big-o-bob
  • Yorkshire
Coolant?
« on: 06 May 2009, 19:53:10 »
Hi all,
Just a quick question...How much coolant do I need to buy?
I am going to get the Vx pink stuff and am I right in saying it should be 50/50 mix?
I am just about to pop in my new oil cooler after a bit of a battle with the oil pipe nuts, so I want to get it right with the coolant.  Cheers :y
RobseyMV6
  • west sussex
Re: Coolant?
« Reply #1 on: 06 May 2009, 20:08:29 »
Yeah just 5 litres will do, when i replaced my water pump and refilled, it took 7 litres, i normaly mix in watering can first and put 50/50 but tried my anti freeze tester to find if was ok but only -5 so i than made it 3.5 litres of anti freeze and 2.5 water, give it a go for your self before you poor in car  :y
HerefordElite
  • Hereford
  • Welcome to the Shire
Re: Coolant?
« Reply #2 on: 06 May 2009, 20:15:02 »
system takes 9.7 litres if i remember rightly :-/ so for 50/50 mix 5 litres of coolant is about spot on.
The last couple of times i have emptied via rad drain and removed top hose, then flushed lots with water so only water in the block then stuck the whole 5 litres in for a pretty perfect mix IMHO :y
Re: Coolant?
« Reply #3 on: 06 May 2009, 20:18:50 »
..... but tried my anti freeze tester to find if was ok  .....
I don't think your coolant hydrometer works properly with pink anti-freeze.  :-/
big-o-bob
  • Yorkshire
Re: Coolant?
« Reply #4 on: 06 May 2009, 20:19:32 »
Thanks.  Very helpful. :y
RobseyMV6
  • west sussex
Re: Coolant?
« Reply #5 on: 06 May 2009, 20:25:36 »
Thats good to know Andy   :D
