Author Topic: coolant maintenance  (Read 3714 times)
Re: coolant maintenance
« Reply #15 on: 06 May 2009, 14:26:52 »
Ive read the guide and all looks very straight forward until the last page. The 2.5TD diesel has a block drain plug, so you can drain the block conveniently...
where and what is the that! where in the guide is pics ? and no ffs please  :( only just worked out what that meant ;D ;D ;D ;D ;D
 ;D ;D
I only done it once on the TD, i *think* its drivers side, towards the back.
Prepared to get wet!  ;D
Rad drain would do for now... just flush it through couple of times
ali
  • hertfordshire
« Reply #16 on: 06 May 2009, 14:31:20 »
iThanks, if I get wet, i will post the pics  ;) ;) ;) ;) ;)
« Reply #17 on: 06 May 2009, 14:32:56 »
OOF Wet T-Shirt Competition, i like it  :y
ali
  • hertfordshire
« Reply #18 on: 06 May 2009, 16:58:50 »
Im all dressed up and not going to get wet ;D not sure I can fit under the car with all these layers on :D :D :D :D and you cant see my t-shirt ;)
« Reply #19 on: 06 May 2009, 17:01:13 »
Thats ok, just more layers to strip off when you do get wet  ;D  :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #20 on: 06 May 2009, 17:02:11 »
Ali, 'PM' me your e-mail address and I'll send you a drawing of the location of the block drain bolt.
« Last Edit: 06 May 2009, 17:05:20 by Reliance505 »
« Reply #21 on: 06 May 2009, 18:41:09 »
funnily enough, that search brought up my guide in double quick time.
And it took me 5 mins to make
You knew what you were looking for!  :-? :y
« Reply #22 on: 06 May 2009, 18:52:41 »
same as anyone else ;) search for coolant in guides!
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #23 on: 06 May 2009, 19:11:27 »
send tunnie your email address and he can send you a drawing of where the maintenance guides are :P
ali
  • hertfordshire
« Reply #24 on: 06 May 2009, 20:33:54 »
Ive found it now thank you :P :P :P :P :P :P and as for draining the blue fluid Im not going to tell you what I found in Syd and Pete  :D I will get another " ffs " from Tunnie  ::) and Im sure he doesnt want my email address :D unlike Sethsmate ;D ;D ;D ;D
