Author Topic: coolant maintenance  (Read 3712 times)
ali
  • hertfordshire
coolant maintenance
« on: 06 May 2009, 13:32:42 »
After reading another thread Ive found something else I have never done :D
 1 Changing the coolant, is this easy?
 2 Cam belt, do I have belt or chain on Pete and Syd. How do I know if I need to change them? I have had Pete for 2 years and never even looked under the bonnet :-[ :-[ until I got Syd last month and joined OOF :y now I live under there ;D ;D ;D ;D ;D
Welung666
Re: coolant maintenance
« Reply #1 on: 06 May 2009, 13:33:50 »
1) Fairly easy yes :y
2) Belt on the V6 and Chain on the tractor. Belt needs changing every 40k or 4 years (whichever is sooner) if unsure get it changed anyway! Chain should be good for at least 250k ;)
« Last Edit: 06 May 2009, 13:35:07 by Welung666 »
ali
  • hertfordshire
« Reply #2 on: 06 May 2009, 13:49:29 »
Next question is there guide for coolant on here?
Will look through Petes paperwork to see if any record of last belt change. :-/ As for Syd, thats more brownie points and another reason keeping him :y :y :y
« Reply #3 on: 06 May 2009, 13:53:53 »
ffs, does NO ONE read the guides section?  >:(
http://www.omegaowners.com/forum/YaBB.pl?num=1167917774
ali
  • hertfordshire
« Reply #4 on: 06 May 2009, 13:57:23 »
yes I do, but mine always seems to be different :-[ :-[ :-[
« Reply #5 on: 06 May 2009, 13:58:09 »
Easy way, do a search, only select guides section, only chose to search titles, and put in the keyword  ;)
going crazy
  • Middlesex
« Reply #6 on: 06 May 2009, 13:58:53 »
TBH, we need a special search facility for the guides section or atleast order them by category
Personally, would have loved to see this guide a few months back - could never find it :'(
« Reply #7 on: 06 May 2009, 14:01:44 »
As above, our search works fine for our needs.
Just select the guides section only when doing a search.
And come on, its only 7 pages, took me all but 15 seconds to find it the manual way
ians
  • Reading
« Reply #8 on: 06 May 2009, 14:05:21 »
we do already - its called 'tunnie' ;)    you just have to put up with the grumpy comment accompanying the result..
seriously I agree with the suggestion. The maint guide section has grown quite a lot - even when you know something is in there its often difficult to find.
ali
  • hertfordshire
« Reply #9 on: 06 May 2009, 14:07:19 »
Some of us are new to this, it all looks the same to me at the moment :( You didnt have to answer if it winds you up that much :P
« Reply #10 on: 06 May 2009, 14:14:49 »
right made this guide....
http://www.omegaowners.com/forum/YaBB.pl?num=1241615661
Lets hope people can find that!
« Last Edit: 06 May 2009, 14:15:28 by tunnie »
« Reply #11 on: 06 May 2009, 14:16:39 »
funnily enough, that search brought up my guide in double quick time.
And it took me 5 mins to make
ians
  • Reading
« Reply #12 on: 06 May 2009, 14:20:34 »
careful, you might end up in an infinite vortex... ;)
going crazy
  • Middlesex
« Reply #13 on: 06 May 2009, 14:21:34 »
Thanks, Tunnie
ali
  • hertfordshire
« Reply #14 on: 06 May 2009, 14:25:29 »
Ive read the guide and all looks very straight forward until the last page. The 2.5TD diesel has a block drain plug, so you can drain the block conveniently...
where and what is the that! where in the guide is pics ? and no ffs please  :( only just worked out what that meant ;D ;D ;D ;D ;D
