Author Topic: Overheating problem  (Read 2974 times)
BgBLizard
  • Yeovil
    • 3.0 MV6
Overheating problem
« on: 06 May 2009, 14:18:20 »
Hi All
I am hoping someone can help me as I have spent sometime trying to fix my Pre facelift 3.0 V6 Mega but have failed so far.
Problem:
Over heats after going about 6miles, lots of steam, it has got progressively worse as it used to do 15miles when I first noticed this.
Symptoms:
Coolant pipes fit to burst.
Radiator stone cold except on ends.
Both fans running flat out.
Engine warms normally thermostat opens water circulates through radiator evenly, fans kick in out normally temperature gauge seems to read correctly but as you drive it gets to a point the coolant seems to stop flowing and it over heats.
Checked so far:
Replaced thermostat twice.
Checked water pump, this has a metal impeller and is firmly attached to the pulley, seal is good.
Radiator flushed, de scaled no sign of sludge or blockage,
Cabin heater works fine.
On this site I found mention of the heater bypass valve but I do not know where this is and how it works so I haven't checked it.
Finally I did a compression test and one cylinder was down so I suspected a blown head gasket, I removed the head only to find that the gasket looks good (I'm not an expert). I now have a car in bits with no sign of a resolution and would really appreciate some help.
Thanks in advance.
Andy
Welung666
Re: Overheating problem
« Reply #1 on: 06 May 2009, 14:24:03 »
De ja vue! I'm sure I've just read this on Vxon ;D
« Reply #2 on: 06 May 2009, 14:24:56 »
Hi All
Problem:
Symptoms:
Checked so far:
Thanks in advance.
Andy
Sounds like the rad is blocked, its stone cold in the centre?
Has it ever had radweld in it?
ians
  • Reading
« Reply #3 on: 06 May 2009, 14:26:03 »
Unlikely to be the head gasket, more likely blocked rad I would say,  or a major air lock, but this is unlikely as you have obviously refilled the coolant several times.
HBV is the black plastic cylindrical device the size of a can of peas behind the drivers side of the engine under the scuttle.  For 30 quid its worth changing.
Were you losing significant coolant?
BgBLizard
  • Yeovil
    • 3.0 MV6
« Reply #4 on: 06 May 2009, 14:37:34 »
Thanks all for the quick responses
I have had the rad out and it dose pass water readily so I did not suspect this. Also it seems to work normally for some time heating all over until the fans cut in.
I will not dissmiss it but it's expensive so is there away of testing it once and for all.
It has not lost any coolent except when it boils :-)
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #5 on: 06 May 2009, 14:41:10 »
sounds like a blocked radiator!
HBV lives at the rear of the block behind the ECOTEC Breather pipes if thats gone you will be loosing water in a drip drip drip fasion from the rear of the engine
if youve overheated the engine then damage may of already been done ie Headgaskets maybe lucky though.......
wheres you location?
« Last Edit: 06 May 2009, 14:41:54 by tmx »
BgBLizard
  • Yeovil
    • 3.0 MV6
« Reply #6 on: 06 May 2009, 14:43:32 »
Thankyou
Yeovil Somerset
BgBLizard
  • Yeovil
    • 3.0 MV6
« Reply #7 on: 06 May 2009, 14:55:48 »
Have just checked there are just two pipes off the bridge between the cylinder heads that go through into the heater matrix so no HBV ?
« Reply #8 on: 06 May 2009, 15:05:31 »
If someone fcking muppet has removed that, no wonder its over pressizing!
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #9 on: 06 May 2009, 15:06:37 »
http://www.omegaowners.com/forum/YaBB.pl?num=1193594464
There be a guide with pics on how to replace the HBV thatll give you an idea of what to look for!
ians
  • Reading
« Reply #10 on: 06 May 2009, 15:08:50 »
Do you not have AC?  (police spec per chance..??)
In that case there would be no HBV.
BgBLizard
  • Yeovil
    • 3.0 MV6
« Reply #11 on: 06 May 2009, 15:23:43 »
Yep sorry it is an ex Police demo so no goodies what so ever
« Reply #12 on: 06 May 2009, 15:25:29 »
lots of steam after 6 miles...? Where is the steam coming from? Filler cap should hold 13psi in the system. Sounds like its not holding pressure and boiling over....
(er.... nervous finger over post button as not good with over heating issues. Never had the problem personally)
BgBLizard
  • Yeovil
    • 3.0 MV6
« Reply #13 on: 06 May 2009, 15:31:51 »
Thanks, also forgot to say i bought a new cap which had the effect of letting go sooner than the old one.
ians
  • Reading
« Reply #14 on: 06 May 2009, 16:26:59 »
worth checking the the expansion tank doesn't have a micro crack in it?
