Author Topic: incorrect boost pressure  (Read 1272 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« on: 06 May 2009, 21:04:37 »
code No 44 incorrect boost pressure. i need to know how to remedy this. i intend to try to do it myself so any advice would be much appreciated  , cheers  :) :) :)
Omegatoy
  • UK
Re: incorrect boost pressure
« Reply #1 on: 06 May 2009, 21:06:45 »
first job is to check the boost pressure hose for blockage, second job is to check the sensor isnt filled with gunge from the induction , tin of carb cleaner is you friend although i have known boost pressure pipes to splt!! :y
« Reply #2 on: 06 May 2009, 21:41:11 »
or a stuck wastegate
Omegatoy
  • UK
« Reply #3 on: 06 May 2009, 21:42:06 »
after the easy ones !!!! ;D
raywilb
    • Citroen C4 Cactus
« Reply #4 on: 07 May 2009, 08:49:11 »
thanks i,ll check the hose (hopefully Ian D will point me in the right direction ) when i find out which hose it is. :-[ :-[ :-[  .will enquire about the gate thing as well. cheers. : :) :)
Ian_D
  • York
« Reply #5 on: 07 May 2009, 09:29:02 »
No probs mate, I will try and help if I can!   :y  ;D
« Last Edit: 07 May 2009, 10:04:29 by Ian_D »
[size=12]
