Author Topic: FAULT CODES  (Read 967 times)
andy wood
  • Ashburton, Devon
FAULT CODES
« on: 07 May 2009, 13:11:19 »
Hi all
I have taken my Omega in for a service.
It wouldn't start a couple of weeks back (turned over but not firing) and RAC man said it was fuel relay but garage have said more likely to be crankshaft or camshaft sensor.
Garage have come up with a fault code on their reader of 31,  to do with rpm signal but their reader does not tell you where the fault is.
Can anybody help please.
ANDY  :)
Re: FAULT CODES
« Reply #1 on: 07 May 2009, 13:18:54 »
Hi all
ANDY  :)
IIRC 31 is the code you get when your engine is NOT running.  ;)
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: FAULT CODES
« Reply #2 on: 07 May 2009, 14:07:50 »
yeah 31 means engine not running
Hope it aint Exminster Garage ??
andy wood
  • Ashburton, Devon
Re: FAULT CODES
« Reply #3 on: 07 May 2009, 14:32:45 »
thanks for replies,
so can you shed any light on the intermittent starting could it be fuel relays or somehting else
p.s. no it's not Exminster garage. lol
cheers
MutantCav
  • Gainsborough
Re: FAULT CODES
« Reply #4 on: 07 May 2009, 14:36:34 »
V6 so will be crank sensor most likely...use genuine Vaux and route as away from exhaust and oil cooler pipes as poss :y
