Author Topic: Urgent - Engine won't start  (Read 3120 times)
Richard A
  • Aldridge, West Midlands
Re: Urgent - Engine won't start
« Reply #15 on: 05 May 2009, 16:38:53 »
So no one thinks it is to do with the 'engine fan' connector falling off ??  :-/ :-/
Thanks for all the comments. :y
regards
richarda
richard a
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #16 on: 05 May 2009, 16:55:16 »
cant see how the fans could prevent the engine from starting?
maybe it has a built in failsafe?
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #17 on: 05 May 2009, 16:57:27 »
Normaly the only thing that would happen there is that the fan would not function. but I could be mistaken. I wouldnt think that theres a connection. could it be an air bubble in the fuel line as it was low on fuel? :-/
He who brakes Looses
To old to die young
Welung666
« Reply #18 on: 05 May 2009, 19:00:19 »
Richard if you fancy a little tootle over to sunny Dudley I can read and clear the codes for you. Nearly always helps to have a 2nd set of eyes look over them too :y
« Reply #19 on: 05 May 2009, 19:24:04 »
right. Apologies to all. I was not clear.
I was translating 31, nothing more.
That aside for a moment. Def sounds like crank sensor to me even if 19 not present imho. But i may well be a bit premature, esp if fuel level low.
To clarify to Richard 31 does not mean crank sensor failure as all have said. Constant cranking and not firing is common with crank sensor failure. To then start i while later is also common warning of cs failure. 19 not present not unusual at this stage, as with my omega. If it happens again within a week or so suspect cs, verifie with paper clip test code 19.
 Sorry mate, made a pigs ear of your thread.
Hope clear to all? Whoops.
Only you mate ;D ;D ;D ;)
However does have symptoms of dodgy crank sensor - suggest check codes again now its been running. If crank sensor there will be a 19 :y
« Last Edit: 05 May 2009, 19:25:17 by dbug »
Richard A
« Reply #20 on: 05 May 2009, 19:29:58 »
Cheers 'Welung 666' Lee, however even with the engine running the only code is '12' over and over, watched it repeat 15 times.
So thanks for the offer but all ok, see what happens in the morning.
I will be going to the ABS/OOF meet at the Plank & Leggit on Sunday 10th May, it's a bit of a run ('A' roads and motorway 35 min from Walsall) but the people and the chat make it worth while, plus the pub is good.
regards
richarda
richard a
andy wood
  • Ashburton, Devon
« Reply #21 on: 07 May 2009, 13:52:33 »
Hi
Just to clarify, what do you mean by a new cs please
andy
« Last Edit: 07 May 2009, 13:53:31 by andrewwood »
Welung666
« Reply #22 on: 07 May 2009, 14:08:21 »
Hi
andy
A new crank sensor :y
andy wood
  • Ashburton, Devon
« Reply #23 on: 07 May 2009, 14:35:35 »
thanx for that.
MutantCav
  • Gainsborough
« Reply #24 on: 07 May 2009, 14:42:26 »
If your going for a bit of a trek May 10 I would buy a genuine aux crank sensor and tak it with you...a) if you break down then the recovery service guy can probably fit it (although I doubt it as they usually say its fuel relay lol) or b) one of the guys at the meet may well be able to fit it for you so you can see its defo the problem (which it almost certainly will be) :y
