Author Topic: Urgent - Engine won't start  (Read 3084 times)
Richard A
  • Aldridge, West Midlands
« on: 05 May 2009, 11:22:06 »
Changing the rad on sunday, all went well, drove the car Sunday and Monday, went to the car this morning, engine will turn over but will not fire, found the connector on the 'engine fan' hanging off so reconnected, checked all other connector things look ok.
Still will not fire, engine management light on and stays while engine turning over.
An help please !!
regards
richarda
richard a
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: Urgent - Engine won't start
« Reply #1 on: 05 May 2009, 11:29:14 »
Try the paper clip test it might help finding out whats wrong.
He who brakes Looses
To old to die young
« Reply #2 on: 05 May 2009, 11:31:18 »
do paper clip test and post up the error codes. Link below :-)
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
« Reply #3 on: 05 May 2009, 11:33:14 »
hang on. What engine you got?
Richard A
« Reply #4 on: 05 May 2009, 11:36:58 »
Sorry 1998 2.5 auto petrol
regards
richarda
richard a
Richard A
« Reply #5 on: 05 May 2009, 11:48:21 »
Paper clip test with just ignition on 12,31 then 12,31 again and again.
Should I be turning the engine over and reading the codes ???  :-[
regards
richards
richard a
Richard A
« Reply #6 on: 05 May 2009, 12:05:20 »
It's started !!!!!!!!!!!
Took out paper clip, turned key, started first time !
Could it of been something to do with the time between replaceing the fan connector and turning the key ie some type of time delay ?
Very strange.
Thanks for your help.
regards
richarda
richard a
« Reply #7 on: 05 May 2009, 12:10:10 »
crank sensor mate.
Edit. 31 no rpm signal. Def crank sensor. Sounds typical.
« Last Edit: 05 May 2009, 12:13:40 by chrisgixer »
« Reply #8 on: 05 May 2009, 12:39:22 »
crank sensor mate.
eh? How do you work that out then?  :-?
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #9 on: 05 May 2009, 12:40:20 »
I thought you always got code 31 one if you paperclipped without the engine running
« Reply #10 on: 05 May 2009, 13:29:45 »
crank sensor mate.
31 no rpm signal.
Sorry rushed it. Boss sniffing about. You dont agree i take it...fuel low?
MutantCav
  • Gainsborough
« Reply #11 on: 05 May 2009, 13:39:27 »
31 with engine off will always come up...no engine running so no crank running so no signal from crank!!
Do the paperclip test again with engine running...
P.S does sound like crank but 31 with engine off is normal for all so proves nothing
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #12 on: 05 May 2009, 13:41:31 »
Code 19 is the crank one mate :y
« Reply #13 on: 05 May 2009, 14:58:35 »
right. Apologies to all. I was not clear.
I was translating 31, nothing more.
That aside for a moment. Def sounds like crank sensor to me even if 19 not present imho. But i may well be a bit premature, esp if fuel level low.
To clarify to Richard 31 does not mean crank sensor failure as all have said. Constant cranking and not firing is common with crank sensor failure. To then start i while later is also common warning of cs failure. 19 not present not unusual at this stage, as with my omega. If it happens again within a week or so suspect cs, verifie with paper clip test code 19.
 Sorry mate, made a pigs ear of your thread.
Hope clear to all? Whoops.
Ghost
    • 2.6 V6 CDX Estate
« Reply #14 on: 05 May 2009, 16:25:50 »
Hi mate
Does your car go over 3500rpm?
I had code 19 and the car would not go over 3500rpm it just spluttered. Got new cs and now no probs. just got to get MOT (Failed on Broken Rear Coil spring and Steering Idler arm :'()
Hope you get it runing the way it should soon :y        Dave.
To old to die young
