Author Topic: vauxhall omega check coolant level Warning  (Read 5846 times)
dave88
« on: 07 May 2009, 20:35:54 »
Hi all
I have a Vauxhall Omega CD 2001
A warning come up saying check coolant level,, Also the temperature needle has stopped working it dose not rise at all,
A mate told me that he thinks its the Coolant tep sensor, So i got a new one to day and removed the header tank I see a plug underneath
the tank but I cant get it out by turning or pulling it is there a certen way you remove this   ;)
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: vauxhall omega check coolant level Warning
« Reply #1 on: 07 May 2009, 20:38:53 »
Firstly
Its far easier to replace the tank with a known worker :y
secondly the temperature sensors have nout to do with the expansion tank theres one on the block and one on the rad
the one on the engine does the temp guage
dave88
« Reply #2 on: 07 May 2009, 20:43:11 »
aww so 2 in total
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #3 on: 07 May 2009, 20:43:52 »
yep one for the ECU & one for the guage
dave88
« Reply #4 on: 07 May 2009, 20:45:01 »
Aaa wonder witch one he sold me  :-/
dave88
« Reply #5 on: 07 May 2009, 20:47:06 »
where abouts would I find the one on the block and the one on the rad  :y
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #6 on: 07 May 2009, 20:47:23 »
guage one is small & threaded ill take a pic of my "Spare" to show you
dave88
« Reply #7 on: 07 May 2009, 20:48:21 »
Thank you tmx :)
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #8 on: 07 May 2009, 20:56:04 »
this is the temp guage
dave88
« Reply #9 on: 07 May 2009, 20:58:45 »
cant see it m8
« Reply #10 on: 07 May 2009, 21:13:53 »
Hi all
which engine?
The tank contains the level sensor, just replace the lot, about £35 IIRC.
V6 temp sensor live right at the back of the V in the centre, if your gauge isn't moving at all I'd suggestthe wire hass come off the sensor.
4 cylinder ..... sorry, don't know. ::)  :y   :y  :y  :y
dave88
« Reply #11 on: 07 May 2009, 21:33:23 »
Hi Thanks for the Pic yes this is the same one I have  :y
where abouts do I fit my New one ?
the engine is a 2198 cc
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #12 on: 07 May 2009, 21:39:44 »
ahh a 2.2 4pot hmm Tunnie Or Welung will know!
« Reply #13 on: 07 May 2009, 21:46:48 »
I think it's still at he back some where, I'd look for a detached wire with spade terminal first though.
dave88
« Reply #14 on: 07 May 2009, 22:02:35 »
do you mean on the header tank andy  :)
