Author Topic: Knackerd NUTs  (Read 1326 times)
the_bed_wrecker
  • SUNNY HARTLEPOOL
  • Where's that stormtrooper gone ?
Knackerd NUTs
« on: 08 May 2009, 19:28:35 »
Hi all,
Well actually its a bolt thats gone, the one thats used for the filler / drain on an autobox, it must be stripped, wont come out and wont tighten up  :-?, any ideas how to get it out ? if I need to take of the sump to get the drain plug out how much liquid is going to pi** out ? and is there anyway too fill up the box without the drian plug out ?
Cheers
TBW
Must be getting old to have one of these !!
Martin_1962
Re: Knackerd NUTs
« Reply #1 on: 08 May 2009, 19:31:30 »
AFAIK 4 to 5 litres and you need to take sump off
the_bed_wrecker
  • SUNNY HARTLEPOOL
Re: Knackerd NUTs
« Reply #2 on: 08 May 2009, 20:07:21 »
Hi thanks for that, a bit of a bummer, was a garage that last done the oil they said they had a problem with the plug, I see why now !!
Does anybody know the part numbers and where to get the gaskets and copper washer for the plug, I have a 2.0l on a X plate.
Cheers
TBW
  • Online Online
Re: Knackerd NUTs
« Reply #3 on: 08 May 2009, 20:11:17 »
Hi all,
Cheers
TBW
http://www.omegaowners.com/forum/YaBB.pl?num=1241806994
You don't need multiple posts asking for the same thing .... we'll see your post! Honest! :y
the_bed_wrecker
  • SUNNY HARTLEPOOL
Re: Knackerd NUTs
« Reply #4 on: 08 May 2009, 20:21:40 »
Thanks again, its a wealth of knowlage this place  :)
One last question for the night - is the autobox sump under high pressure ? I started the engine and even though the plug is gone there wasnt any oil coming out, will it when upto temp ?
Got long trip tomorrow to pick up a car, so will be towing a bit of weight and dont want to get stranded, will the trailer give the box problems when the oils a bit low. (joined RAC just incase !)
Cheers
TBW
  • Online Online
Re: Knackerd NUTs
« Reply #5 on: 08 May 2009, 20:27:04 »
Cheers
TBW
it's not under pressure, there's a vent tube at the back of the engine. Your fill plug is also you level plug, so when your engine is running you're oil level should be level with the plug. I'd be surprised though if nothing at all came out.  :y
the_bed_wrecker
  • SUNNY HARTLEPOOL
Re: Knackerd NUTs
« Reply #6 on: 08 May 2009, 20:30:19 »
Hi, Where's the vent tube at ? I wonder if I can top up the box by pouring oil down that  :D
  • Online Online
Re: Knackerd NUTs
« Reply #7 on: 08 May 2009, 20:38:16 »
At the back of the engine bay.
And no .... you can't top up with it!  ;)
