Author Topic: 2.2 Exhaust Downpipe  (Read 2813 times)
Iain
« on: 03 May 2009, 23:18:17 »
Ok guys here is my problem......
My EML is on....Quick rundown...
In the last week the car has had,new
Downpipe
EGR valve
Full service
Got new downpipe fitted,all good til next day EML comes on,phones AA,plugs it in and (cant remember code) basically the 'voltage' reading between the 2 exhaust sensors are not 'within tolerance'
Back to garage,gets another new downpipe fitted.......and whilst its there it gets full service.....all good......til.....
2 hours later,drives it and it starts to mis-fire slightly,then heavily.... gets it home and it goes back to the garage(no EML at this point),it gets plugged in again which shows 'mis-fire 1&2 and EGR valve fault....
So it gets a new EGR valve,all good again...
Driving great,much better response from pedal and generally feeling brill........
Last night....feels a tiny bit sluggish again and 10 mins later EML  >:(
Its not in 'limp' but the bloody light is on,phoned my mate and he reckons it could be one of the Lambda sensors,but im not sure...
I know what it is though..........getting annoying!!!
Anybody had the same or came across this?
Any help would be great,my mate who owns the garage is good,but no GM specialist so i need to try figure it.
Im hoping to get through to see hotel21 next week for software updates,so want to try solve it before i go........
Thanks in advance...
Re: 2.2 Exhaust Downpipe
« Reply #1 on: 03 May 2009, 23:34:12 »
If you're going to see H21, get him to look at the live data while you drive :y
Iain
« Reply #2 on: 04 May 2009, 00:03:49 »
My mate with the garage has a Snap-on handheld which is good enough but obviously a Tech 2 will be better....so i will ask h21,
Was hoping someone had the same problem....i just want it sorted ;D
Begining to pee me off now :y
Cheers
Iain
« Reply #3 on: 04 May 2009, 19:02:42 »
Anyone else had this problem??
Iain
« Reply #4 on: 05 May 2009, 10:18:30 »
Bump  :y
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #5 on: 05 May 2009, 10:46:56 »
All wires connected properly? Someone here had recently similar trouble, the reason was that the sensors had been cross-wired. Re-re-check the lambda-sensor connectors that they are on correct sensor and correctly fitted all the way.
Iain
« Reply #6 on: 05 May 2009, 10:58:51 »
Wires checked mate all looks fine.......
Im guessing it will come up with 'Cat Efficency' again.....
Im wondering if the 2 sensors have been mixed up? although i would have thought the EML would have come on straight away......It ran for 2 days feeling great,very responsive and quick,then the light came on and it felt slightly sluggish....
Who knows? :)
Iain
« Reply #7 on: 05 May 2009, 12:47:14 »
Ok peopl found my AA report...
Codes that were stored were...
P0420 and
P1781
Anyone confirm what they are?
Cheers
Iain
« Reply #8 on: 05 May 2009, 13:20:07 »
P0420 is Cat efficiency,now my new downpipe has no pre-cat box,just the pipe,as it seems that this is all thats available now,
Is this the reason my EML is coming on?
Any help would be great guys......
Iain
« Reply #9 on: 05 May 2009, 21:53:07 »
All the people on here and no one can help me.... :(
Or have a just uncovered a brand new fault?
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #10 on: 05 May 2009, 21:54:53 »
if this is the same buisness as the 3.2 then the best thing to do is move the sensors to behind the main cat :y
Iain
« Reply #11 on: 05 May 2009, 22:00:52 »
Ok,how do i do it then? ;D
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #12 on: 05 May 2009, 22:02:13 »
from reading on here i think you move the precat sensors behind the main cats ie drill em in i think albatross done it to his 3.2
Iain
« Reply #13 on: 05 May 2009, 22:05:50 »
Ah,ok.....and then weld up the pre-cat hole?
pauldmackay
« Reply #14 on: 05 May 2009, 22:13:04 »
You can't, if you've only 1 cat.
You'll have 1 lambda before and after the cat.
I've the same 2.2 as you, had the downpipe replaced twice now due to p0420 errors, last time by vauxhall dealer and there replacement only had 1 cat too, so again, 1 lambda before the cat and 1 after.
The orginal had 2 cats, the pre cat heats up rapidly.
Still got the p0420 issue, had new geuine lambda's fitted, tried v-power and bp ultimate, neither resolved the problem.
Car passed MOT no problem like this a few months ago. Fed up now so I just ignore it and reset the light when it comes on, the car behaves the same with the error as it a monitor issue only.
Turning out to be a common issue now, basically it's cheap cats thats now supplied by vauxhall, only work properly when up to temp and as theres only 1 thats further away from the engine it takes longer to heat up, so longer to work properly and thus the p0420 error.
