Author Topic: help  (Read 1689 times)
sammylou35
help
« on: 08 May 2009, 20:52:27 »
come on you lot, ive asked the question i need help with this, im a damsel in distress. once ive had it jump started its ok, what is that whizzing noise when i turn the ignition off, seems to of only started to make this noise since i had a new cd player put in.   :'(
Re: help
« Reply #1 on: 08 May 2009, 21:35:39 »
Eh....any more info....or is it in another post in the wrong section  :y
sammylou35
Re: help
« Reply #2 on: 08 May 2009, 22:04:28 »
this is what happens
when i am driving and i turn off the ignition i get a sort of whistling noise think its coming out of the speakers and then if i turn the key then it wont start twice this wk its happened had to get somebody to jump start me any ideas
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: help
« Reply #3 on: 08 May 2009, 22:13:25 »
Why would you turn off the ignition while your driving?
Is your battery flat?
Do you have any EML codes?
What car do you have?
Pete Elite
  • Uxbridge, Middlesex
Re: help
« Reply #4 on: 08 May 2009, 22:23:12 »
  Have you got a Roger Whittaker CD stuck in the player ;D ;D ;D.
Onkel Per
  • Frederikshavn - Denmark
Re: help
« Reply #5 on: 08 May 2009, 22:49:39 »
 :D Roger Whittaker CD  ;D
As surggested in your other threat. When problem show, try disconnect the headunit.
If that solves the problem, then there's one of the wires that needs to be removed from the ISO-connector.
MutantCav
  • Gainsborough
Re: help
« Reply #6 on: 08 May 2009, 23:09:02 »
You mean if you turn the key in the ignition to the start motor position while the engine is already started and running?? The starter motor whizzes round trying to start and already running engine and makes a horrid noise as a result of it grinding??
If the car jump starts but will not start of its own accord...probably either the starter motor or maybe the crank shaft sensor...
« Last Edit: 08 May 2009, 23:09:55 by ShieldOfSteel »
sammylou35
Re: help
« Reply #7 on: 09 May 2009, 09:35:02 »
no its not that if i get in my car and go out for a ride its fine but then say i pull over turn off the ignition pull out the key and then start it up again its as if the battery has suddenly died on me but when its jump started again its fine any ideas
Bumbazor
  • Worksop
Re: help
« Reply #8 on: 09 May 2009, 10:44:41 »
Alternator or battery probably. Does it ever start ok without requirig a jump start?
M0T0RVATE
  • Orpington
    • 94 Omega Elite Saloon 3L
    • MOTORVATE STUDIO
Re: help
« Reply #9 on: 09 May 2009, 10:50:14 »
Possibly the wiring fom the ignition to the starter motor.
The wires attached to the starter motor solenoid can
cause this problem if they are loose or dirty.
Had this on my Senator B last summer. Cleaned and
renewed wiring connectors to starter solenoid, and had
no more problems...
 :) :y
sammylou35
Re: help
« Reply #10 on: 09 May 2009, 12:10:37 »
yes it starts fine every day just seems to happen when i have been out and about in it. drove 150 miles yesterday got off the motoway to stop at the shop got back in the car and it was if the battery had died all of a sudden. been this morning and all is normal for now anyway
Re: help
« Reply #11 on: 09 May 2009, 13:25:50 »
Seeing as, on another post, this only happened after you fitted the radio....   ....so to state the obvious, but have you tried removing said radio?
