Author Topic: Self levelling spension question....  (Read 1144 times)
Welung666
« on: 08 May 2009, 18:25:45 »
I realised a while back my self levelling wasn't working and put it down the the NSR shock slowly pi55ing all it's oil out. Fitted the replacement yesterday with the hope it would cure it but alas no :( IIRC it's connected to fuse 15 on my 96my which is fine as the radio is still working. Any ideads where to start looking for another cure?
Re: Self levelling spension question....
« Reply #1 on: 08 May 2009, 18:53:52 »
Try again... I thought I'd beat the outage! ::) ::) ::)
Have you checked the sensor... NSR arm IIRCC.
They have a habit of popping off or sticking
« Reply #2 on: 08 May 2009, 18:56:41 »
Try again...  ....Have you checked the sensor... NSR arm IIRCC.
The suspension level sensor is on t'other side of the car. Nearside sensors are for the HID headlights (if fitted)  ;)
Does your compressor run shortly after you start the car? Compressor lives under the front bumper/driver's side wing!
« Reply #3 on: 08 May 2009, 19:04:23 »
Doh!
« Reply #4 on: 08 May 2009, 19:07:36 »
Doh!
 ;D  ;D  ;D :y
Welung666
« Reply #5 on: 08 May 2009, 20:58:38 »
Yes SAI compressor runs for about a min after startup. Where is the sensor? Is it not the one bolted to the OS of the diff?
« Reply #6 on: 08 May 2009, 22:45:59 »
SAI?? That lives under the passenger wing I believe, however that's a different animal from the suspension compressor.  ;)  ;)  ;)
« Reply #7 on: 08 May 2009, 23:00:51 »
level sensor is drivers side rear, between dif and fuel filter on mine. 4 by 2 box with a right angle arm and rose joint connector rod. If you lie by the side of the car and reach under, rear wheel in your left arm pit, with a flat blade screw driver and lever the bottom rose joint off, you can raise the sensor arm fully.
Then the car, and wait for the level pump to start, if it does the car should rise to max hight.(handy for changing fuel filter or what ever) You can sit on the rear bumper with the boot open with feet on floor and feel it rise. If nothing happens and pump still runs you have no air output from the pump or its leaking, so you should hear a his, you can pull the R Clip off the shock body above the wheel and see if there is air output. Hth
« Reply #8 on: 08 May 2009, 23:03:20 »
ps self level pump is behind bumper drivers side. Forward of front wheel under air box. Look up from the floor.
« Reply #9 on: 08 May 2009, 23:06:42 »
Is that an echo echo echo in here?  ;) ;)
« Reply #10 on: 08 May 2009, 23:33:48 »
No no.  :-)
Welung666
« Reply #11 on: 09 May 2009, 21:51:28 »
Had a quick look and Fuse 27 had blown turns out it's the self levelling pump ;D ;D  ::) Not had chance to do any more other than change the fuse as I haven't been anywhere today ;D Been busy relining the fish pond  :-?
Page created in 0.028 seconds with 16 queries.
