Author Topic: variable wiper arm  (Read 1088 times)
jack68
  • Berkhamsted Hertfordshire
variable wiper arm
« on: 08 May 2009, 10:02:39 »
Good morning,  i've just bought a variable iper arm from Marky Mark and he's also supplied a relay.  Firstly where are the relays for the wipers and secondly is it a straight swap.
JACK :o
Re: variable wiper arm
« Reply #1 on: 08 May 2009, 10:16:18 »
Relay is in fusebox under steering whell.
straight swap if you have the little bit of wiring tucked up behind cowling
jack68
« Reply #2 on: 08 May 2009, 10:18:19 »
Forgot to ask the wiper arm has another lead with a square plug on and it doesn't appear to fit a plug that i have.  Do i need to plug that in?
dpanic88
  • West Midlands
« Reply #3 on: 08 May 2009, 19:54:21 »
Hi, does your plug have only three pins - where the variable one has five (If memory serv's) - I have cd model and its the same the 5 pin ones are on the elites. But not to worry there is a post about getting round this you have to swap over the three pin connector to fit and then join in the two remaining wires. I'll have a look for the post and send you the link - unless someone beats me too it. Regards
jack68
« Reply #4 on: 09 May 2009, 16:32:02 »
Excellent work, yes mine has the 3 pin and the one i've bought has 5.  I've looked for the fuse/relay and can't seem to find where that goes either.
JACK
dpanic88
  • West Midlands
« Reply #5 on: 09 May 2009, 19:38:52 »
Hi, this should be the correct link.
http://www.omegaowners.com/forum/YaBB.pl?num=1225410105/23#23
As for the relay - I'll check and locate the  correct position. Regards.
dpanic88
  • West Midlands
« Reply #6 on: 09 May 2009, 22:49:31 »
plus - relay is in the engine comp for this
check the tech guides for your eng and layout of fuse box :y :y
