Author Topic: Bonnet opening  (Read 1330 times)
dave88
Bonnet opening
« on: 07 May 2009, 22:01:05 »
Hi I have a vauxhall omega 2.2  2001
when I pull the bonnet catch in the car it wont open the bonnet it just goes to fully pulled and nothing happens
so I have to dismantle the pull leaver and pull the wire with a
pliers and pull it realy hard to get the bonnet to click open
can I adjust it at all ?
Thanks Dave  :)
Re: Bonnet opening
« Reply #1 on: 07 May 2009, 22:04:53 »
yup.
you'll see 8mm bolt that holds cable just in front of battery. Undo, pull the cabel until the catch just starts to move, and tighten
Re: Bonnet opening
« Reply #2 on: 07 May 2009, 22:25:53 »
yup.
you'll see 8mm bolt that holds cable just in front of battery. Undo, pull the cable until the catch just starts to move, and tighten
Isn't it under the trim panels from across the slam panel?
Re: Bonnet opening
« Reply #3 on: 07 May 2009, 23:39:41 »
In the mean time get someone to push down on the bonnet, pull the lever and it should get the bonnet open with out dismantling.
mine is loose at the moment.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Bonnet opening
« Reply #4 on: 07 May 2009, 23:43:49 »
As already said really, remove the small triangular shaped plastic cover in front of the battery, then you will see a 6mm bolt which has an 8mm head holding a small clip that tightens over the bonnet release cable, slacken it and pull it about half an inch, that should be to much, then bit by bit let it go back until the bonnet opens properly with the handle. :y
dave88
Re: Bonnet opening
« Reply #5 on: 08 May 2009, 00:02:54 »
Thank you guys I will try that first thing in the morning ill let you know how I get on
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Bonnet opening
« Reply #6 on: 08 May 2009, 00:04:31 »
Good stuff you should manage it  :y
Re: Bonnet opening
« Reply #7 on: 08 May 2009, 10:24:45 »
yup.
yup, which is what I tried to say (badly!)
dave88
Re: Bonnet opening
« Reply #8 on: 10 May 2009, 00:20:10 »
Job done Thank You Guys for your advice it was spot on  :y
