Author Topic: leccy seats  (Read 2056 times)
omegav6est
  • corsham wiltshire
leccy seats
« on: 07 May 2009, 22:43:38 »
hi all my mig has a seat with only 1 electric function,the up and down bit, i have the chance of a elite interior which has a multi function seat, im not worried about the wing mirror memory thing but can i fit this to my mig and get it to work easily enough? thanks
GG
  • Milton Keynes
  • If kicking doesn't work, then hit it with a hammer
Re: leccy seats
« Reply #1 on: 07 May 2009, 22:48:30 »
I know others have succesfully fitted without problems, from memory the the general power supply wire is the same, it only gets clever in the seat itself, I think, will check tomorrow  :y
omegav6est
  • corsham wiltshire
Re: leccy seats
« Reply #2 on: 07 May 2009, 22:49:59 »
thanks kick the mule.
GG
  • Milton Keynes
Re: leccy seats
« Reply #3 on: 07 May 2009, 23:05:53 »
Just checked mine with a torch. I got two power feeds
1. for the heated seats
2. to the clever box that does the multi function seats
Check this to be sure
http://www.omegaowners.com/forum/YaBB.pl?num=1234703021
 :y :y
« Last Edit: 07 May 2009, 23:06:16 by grahamandnatalie »
omegav6est
  • corsham wiltshire
Re: leccy seats
« Reply #4 on: 07 May 2009, 23:28:28 »
so hopefully when i connect my power feed to the new seats the little box o tricks underneath should do the rest...sweet.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: leccy seats
« Reply #5 on: 07 May 2009, 23:40:03 »
You can also put in the plug and solder three further wires and hey presto  :y
omegav6est
  • corsham wiltshire
Re: leccy seats
« Reply #6 on: 08 May 2009, 00:18:47 »
can you explain that loo-knee?
omegav6est
  • corsham wiltshire
Re: leccy seats
« Reply #7 on: 10 May 2009, 09:59:42 »
ooops sorry i meant can youexplain that Jedi Master Scrote Scratcher
nixoro
  • Hitchin, Herts
Re: leccy seats
« Reply #8 on: 10 May 2009, 11:11:23 »
Hi
Assuming yours is an earlier omega should be the same
I fitted leather to my old mig
I was lucky enough when fitting the drivers seat to have a piece of loom with the connector that connects in under the seat if you can its just a case of snip the original connector for the up/down and using a nylon connector(?) join the loom with connector to original wiring and hey presto sorted.
The rest of the seats just wire in as normal
hth
Roy :y
« Last Edit: 10 May 2009, 11:12:03 by nixoro »
