Author Topic: TD Missfire  (Read 1383 times)
semisheen
  • Chesterfield
TD Missfire
« on: 10 May 2009, 11:30:36 »
Hello again
when cold it seems to mis verry slightly usualll between 700-1500 rpm at idle it never misses a beat .its been like it for the past month / since ive owned it
when its warm there are no problems
any ideas ?
Re: TD Missfire
« Reply #1 on: 10 May 2009, 12:36:50 »
at initial start up? Does it improve after about 100yrds or so?
semisheen
  • Chesterfield
Re: TD Missfire
« Reply #2 on: 10 May 2009, 12:39:08 »
yeah ...or a couple of minitues
Re: TD Missfire
« Reply #3 on: 10 May 2009, 12:40:52 »
Could be a failing glowplug, which can cause one cylinder not to burn as efficiently until cylinder has sufficiently.  Normally only for a few secs though....
semisheen
  • Chesterfield
Re: TD Missfire
« Reply #4 on: 10 May 2009, 12:46:53 »
Thanks TB
you know that atmosfecic valve the one i was onabout lat week ?
whats that for ?
Re: TD Missfire
« Reply #5 on: 10 May 2009, 12:50:18 »
Thanks TB
whats that for ?
Which one, the normal atmospheric sensor? Thats to measure the atmospheric pressure (and thus be able to make judgements on fuelling based on atmospheric pressure)
semisheen
  • Chesterfield
Re: TD Missfire
« Reply #6 on: 10 May 2009, 12:55:23 »
Yeah thats the 1 ........thanks again
George
