Author Topic: waterleak help please...  (Read 1157 times)
mathewst
  • Split, Croatia
    • v40
« on: 10 May 2009, 15:02:24 »
Recently had a huge trouble with my mig.
Waterpump broke, cambelt valves etc went off.
That was all changed, the car was picked up the day before yesterday and I went on the trip yesterday.
And now the car is loosing water (aprox 1liter per 100km on open road).
I'm already going mad, not sure what is the problem and where is the leak.
Guessing it is the waterpump.
I'll post a few pics, anyone with a good knowledge please PLEASE help.
Here is the link.
http://img228.imageshack.us/gal.php?g=picture001joc.jpg
http://yfrog.com/6cpicture001jocjx
star_whites
  • Rotherham
Re: waterleak help please...
« Reply #1 on: 10 May 2009, 15:59:18 »
At a rough guess Id say that your water pump has not been seated correctly and is leaking under pressure  :-/
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 10 May 2009, 16:24:13 »
Thanks star whites, but woul like a little better advice before going on a return trip home today.
So someone pleaseeee help
star_whites
  • Rotherham
« Reply #3 on: 10 May 2009, 16:31:19 »
Well from the photos you put up your not going to get a definate answer to the problem.
The water appears to be situated below where the water pump if fitted, however there is also a flange that mounts to the side of the engine with two hoses going to it, but I would doubt that it is this as I would have thought that the water would run down the side of the engine and not the front of the engine. Other than that there are no more water hoses in the leaks area so without removing the timing cover and taking more photos I dont think your going to get much more than a guess.
Sorry I couldnt be more help  :-/
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #4 on: 10 May 2009, 19:25:47 »
Not sure if this helps BUT...my mechanic installed non-VX pumps and both failed within a week or so..failed as in leaked water.
Insisted he put a VX pump on and never had a problem since.
mathewst
  • Split, Croatia
    • v40
« Reply #5 on: 11 May 2009, 10:07:13 »
Thanks Duggs, will try to check this today?
How big was the leak if you can remember?
