Author Topic: Radiator draining  (Read 2532 times)
ScottieMV6
  • Swinton, Manchester
Radiator draining
« on: 10 May 2009, 15:49:02 »
Right got everything back together after changing the oil cooler and wondered if anyone had any tips for getting the radiator drain plug out?
Tried mole grips and pliers and short screwdriver but all too big!!!  :D
I'd rather be scared to death than bored to death!!
Re: Radiator draining
« Reply #1 on: 10 May 2009, 15:54:42 »
It don't come out - it opens.  Turn red plastic bit anti-clockwise - yoy may need mole grips to get it started.  To shut tighten by hand! :y
Bumbazor
  • Worksop
« Reply #2 on: 10 May 2009, 16:13:14 »
I would have thought it does come out, to change the o rings.
I remember Jedi Master Scrote Scratcher posted a picture of one recently.
Scottie, is this what you need? If you only want to drain coolant, no need to remove it, just turn and it opens.
« Reply #3 on: 10 May 2009, 16:31:40 »
Would have thought he wanted to flush the system through as he's just changed an oil cooler  :-?
ScottieMV6
« Reply #4 on: 10 May 2009, 16:37:50 »
Yes just need to flush. I didn't mean out I meant open!! Sorry for confusion.
I'll give it another go with the mole grips tomorrow!  :y
« Reply #5 on: 10 May 2009, 16:39:41 »
It will come out, but it doesn't need to to drain the coolant. As said, I've had to start mine of with water pump pliers.  :y
It was me who posted the picture ....  ;)  ;)  ;)
« Reply #6 on: 10 May 2009, 16:40:41 »
You could always drive up the road .......  ;)  ;)  :y :y
ScottieMV6
« Reply #7 on: 10 May 2009, 17:26:05 »
Do you mean to yours Andy? I don't fancy driving it until I have cleared out all the sludge from the cooling system?  :y
« Reply #8 on: 10 May 2009, 17:43:30 »
Yes I did mean to my house. The run would help the flush do its job!  ;)  ;)  ;)
ScottieMV6
« Reply #9 on: 10 May 2009, 17:49:05 »
Ok thanks Andy. I haven't even tried to start it yet so will do that tomorrow and then let you know.  :y
« Reply #10 on: 10 May 2009, 17:52:31 »
I'll be around till around 12:30 tomorrow - then off to work :'( - if it's any use to you.  :y
ScottieMV6
« Reply #11 on: 10 May 2009, 17:56:08 »
Got an appointment in the morning with daughters headteacher so won't get started on it till late morning.
I'll have another go at getting it open myself tomorrow. If not i'll make sure the car starts and then think about coming to yours later in the week (Tuesday is a no go for me).  :y
« Reply #12 on: 10 May 2009, 18:06:27 »
OK I'm on afternoons all week though. POETS day Friday though so finish at 7:30 and home for 8:30
ScottieMV6
« Reply #13 on: 11 May 2009, 11:16:21 »
Something just ocurred to me Andy. My car is on SORN at the minute till I get a few jobs done so won't be able to come to yours!
« Reply #14 on: 11 May 2009, 11:59:52 »
...... My car is on SORN at the minute ......
Ah! That'd be a problem! I could call round one morning this week if you're around if you wanted.
Page created in 0.06 seconds with 16 queries.
