Author Topic: Noise from back - creak - what was fix?  (Read 3315 times)
Martin_1962
« on: 08 May 2009, 13:51:16 »
My car has developed that annoying creak from the back, what was the fix on TIS?
Thanks
Welung666
Re: Noise from back - creak - what was fix?
« Reply #1 on: 08 May 2009, 13:51:59 »
Thanks
Less sprouts ;D ;D
ians
  • Reading
« Reply #2 on: 08 May 2009, 14:09:49 »
tell her to get out.. ;) ;D
« Reply #3 on: 08 May 2009, 14:10:21 »
Watching this one... I've got the same ::) ::)
Welung666
« Reply #4 on: 08 May 2009, 14:12:02 »
I know my Chavalier used to get it, went away when I changed the rear shocks. Turned out the rubber bush at the bottom was turning causing a low down creaky kind of noise.
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #5 on: 08 May 2009, 14:12:24 »
Yeah me too  :y :y
ians
  • Reading
« Reply #6 on: 08 May 2009, 14:16:17 »
shocks and springs ok?  the spring can break at the top/bottom such that its visually not obvious.
or rear subframe bushes?
« Reply #7 on: 08 May 2009, 14:27:00 »
New springs fitted... That's when the noise started! I think it's the spring rubbing on the rubber cups :-/ :-/
lou
  • Romford
  • Always expect the unexpected
« Reply #8 on: 08 May 2009, 14:44:02 »
I have this creaking type noise aswell on occassion especially when dry , improves when wet. Sprayed last saturday all rubber bushes at the back with Silicone spray (available at B&Q)and it appears the noise  has gone or is very much reduced...hope this is of some help
Martin_1962
« Reply #9 on: 08 May 2009, 19:02:14 »
I thought it involved hitting something?
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #10 on: 08 May 2009, 19:07:09 »
According to TIS you have to remove the rear seat cushion
"Bend the sheet metal of lower floor pan in the area of crossmember (receiver for rear seat) with suitable tool (through the first opening in crossmember) downwards (beat out)"
Picture isn't very clear unfortunately :(
Trade club card holder
Code scanner available
« Reply #11 on: 08 May 2009, 19:10:41 »
I posted the fix some while back ... but I'll be damned if I can find it ... :(
alexandjen
  • The Silver Surfer
« Reply #12 on: 08 May 2009, 19:12:40 »
Is it the same as the fix I posted above?
Martin_1962
« Reply #13 on: 08 May 2009, 19:12:51 »
Sounds like the one :y
Martin_1962
« Reply #14 on: 08 May 2009, 19:13:21 »
That was what I was thinking of - well that is where the creak comes from
Page created in 0.023 seconds with 16 queries.
