Author Topic: Where is the thermostat on a V6?  (Read 1026 times)
mark p m
« on: 12 May 2009, 07:33:12 »
And does anyone know roughly how long it takes to remove and replace?
Re: Where is the thermostat on a V6?
« Reply #1 on: 12 May 2009, 07:40:21 »
How long is a piece of string?  ::)  ;)  ;)  ;) It's burried here.
http://www.omegaowners.com/forum/YaBB.pl?num=1229464812
amba
  • Medway towns
    • German V6
« Reply #2 on: 12 May 2009, 07:41:49 »
Should be able to do in a couple of hours provided you don,t have grief with the hidden bolt !!!
Check out the maintenance guide as ther is exact details how to do it.
Don,t forget to replace the "0" ring seals on the coolant transfer pipe.
Be warned ther is wquite a lot to strip out first so if you need to do other work in that area worth combining them..oil cooler/plugs/leads/cam cover gaskets/breathers.
Best of luck with it.
Page created in 0.008 seconds with 16 queries.
