Author Topic: off side rear brak caliper is leaking  (Read 2348 times)
stod
  • hartlpool
« on: 12 May 2009, 11:33:52 »
 hi all.
my caliper is leaking drastically.
will any of you guys happen to have a spare rear caliper to fit the 2.6 v6 model. im sure the 3.2 ones are the same too.
if any of you do happen to have one would you sell it to me please as im having real trouble finding one at any of the breakers yards in this area. thanks
Iain
Re: off side rear brak caliper is leaking
« Reply #1 on: 12 May 2009, 11:35:55 »
Where is it leaking from?
« Reply #2 on: 12 May 2009, 11:39:04 »
Do/should you have vented discs at the back? Only asking as MikeDundee had a leak & it was due to NON vented discs having been fitted instead of the proper vented discs  :o. Eventually one piston tried to make a bid for freedom!  :-?  :-?  :-?
Are there seal kits available?  :-/  :-/  :-/
« Reply #3 on: 12 May 2009, 11:42:03 »
Seals should be fine.....whats the betting its got non-vented discs on a vented setup and one of the outer pistons is protruding a little to far!
« Reply #4 on: 12 May 2009, 11:44:36 »
.........whats the betting its got non-vented discs on  .....
If so .... would they be 'go-faster' brake discs??   ::) ::)  ::)  ::)  ::)
 ;D  ;D  ;D  ;D
stod
  • hartlpool
« Reply #5 on: 12 May 2009, 11:49:34 »
hi thanks for the replies.
i know they are meant to be vented but i havnt checked them to see i,ll go and do that now.
 if i find thats the problem can i reseal the caliper as it is leaking fron the piston
« Reply #6 on: 12 May 2009, 11:51:25 »
Yes, if you open the brake bleed point and gently push the piston in with a suitable tool whilst keeping it square then you will be fine.
« Reply #7 on: 12 May 2009, 11:53:46 »
If it is, as Mark has said, one of the pistons (outer IIRC) has popped/popping out of its bore because the solid disc is only about half the thickness a vented disc. That piston then is half way out even with a new pad in, as the pad has worn ...... the pistion has come out.. You need the correct discs in there after you've carefully pushed the piston back in.
stod
  • hartlpool
« Reply #8 on: 12 May 2009, 12:00:23 »
thanks guys its as you'v guessed someone has put solid disks in the back so im off to get corect disks now.
i have a caliper pusher that fill help me push piston back in so wish me luck it should solve the problem
« Reply #9 on: 12 May 2009, 12:03:37 »
I don't think afetrmarket vented discs for the rear are very common, which is why you've possibly got what you've got. OE discs aren't badly priced if you have access to a Trade Club card.
Careful pushing the pistons back in, do it nice & slowly :y .... you can bugger up your master cylinder seals.
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #10 on: 12 May 2009, 12:19:39 »
Hi Andy, Give this No. a Call. 0191 5108868. Its From Sunderland Metal Co. in Woodbine ter. Sunderland. They Have 2 Omegas there, Both 6 cyl. they are not bad with the price and for £5 more they take it off ready for you to collect :y
He who brakes Looses
To old to die young
« Reply #11 on: 12 May 2009, 12:21:16 »
When you push the piston back in, open the bleed nipple first....
« Reply #12 on: 12 May 2009, 12:21:57 »
They would need to be post 2001 V6's  :y
Ghost
    • 2.6 V6 CDX Estate
« Reply #13 on: 12 May 2009, 12:31:04 »
I Belive they are both T reg so 99 built, ones a diesel the other a petrol dont Know if theres a difference in the Brakes.
To old to die young
« Reply #14 on: 12 May 2009, 12:32:58 »
Vented rear discs were not fitted until 2001  :y
