Author Topic: Camber Adjustment  (Read 1556 times)
megaomega123
Camber Adjustment
« on: 12 May 2009, 16:39:18 »
My osf camber is sitting at -2.75 How do I adjust it back to the -1.1 where it should be?
Can you get the offset bolts from vauxhall?  :-?
Andyb
  • Lincoln
Re: Camber Adjustment
« Reply #1 on: 12 May 2009, 16:49:52 »
you have to undo the nuts on the hub to shock and ajust that way with a spirit level
but you will never get it 100% mate
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #2 on: 12 May 2009, 17:11:46 »
Yep, then a trip to you local alignment people is a must for accuracy!
megaomega123
« Reply #3 on: 12 May 2009, 17:16:55 »
How do you adjust after undoing bolts? The bolts go through at right angles to the camber line.
megaomega123
« Reply #4 on: 12 May 2009, 17:17:54 »
I have access to laser alignment equipment and camber/castor reader.
« Last Edit: 12 May 2009, 17:18:11 by phate321 »
Andyb
  • Lincoln
« Reply #5 on: 12 May 2009, 17:49:05 »
when bolts are loose the wheel will move from the top either in or out
megaomega123
« Reply #6 on: 12 May 2009, 17:54:02 »
Thanks for that. I shall have a bash tomorrow or next week.  :y
Andyb
  • Lincoln
« Reply #7 on: 12 May 2009, 18:25:23 »
do it asap or it will chew your tyres  :y
