Author Topic: Autogearbox - To much fluid !!  (Read 3013 times)
Iain
Re: Autogearbox - To much fluid !!
« Reply #15 on: 13 May 2009, 10:19:10 »
Used to use this method in Carlton/Senators etc for Power steering fluid and brake fluid as well,sook out as much as you can without creating a problem,top up with new fluid,repeat a couple of times a week.....it will re-fresh a fair bit of fluid through the systems
« Reply #16 on: 13 May 2009, 10:24:39 »
yup, your not wrong, and as you say, done like this not a tricky or expensive job.
to do sumps and new filters, 10 litres good atf, looking at about £80
less without filters and using instant gasket
yours guessing about £20 for a nice freshen up  :y
Iain
« Reply #17 on: 13 May 2009, 10:26:40 »
Takes half an hour to sook and re-fresh mate.....it might not be a lot but it should help a bit
It worked with the brake fluid on a GSi i had,brakes were rubbish....sooked and re-freshed the fluid about 4 or 5 times....was browny/black and horrid...4/5 times doing it got to the stage when the fluid i was sooking out was a better colour,brakes were much better and it was easy to do :y
« Last Edit: 13 May 2009, 10:28:47 by Iain »
