Author Topic: It passed the MOT.. Afew other bits to sort.. help  (Read 1249 times)
jampot1979
  • stevenage, hertfordshire
« on: 13 May 2009, 18:08:46 »
Hi, Well the omega 2.2 16v which I was given passed its mot... just.
Has one advisory:
Front discs/pads 75% worn. Is it an easy diy job?
Re: It passed the MOT.. Afew other bits to sort.. help
« Reply #1 on: 13 May 2009, 18:13:44 »
dead easy, have a look in the maintenance section, there's a how-2-do there.  :y  :y
Best using OE discs, pattern discs tend to warp.  :y  :y  :y
Markjay
  • London
« Reply #2 on: 13 May 2009, 18:30:53 »
As said...
It is not clear however if the discs are also worn, or only the pads? You may get away with replacing just the pads if the discs are OK - the pads alone are just over a tenner.
Alas, no more Omegas....
