Author Topic: trays  (Read 1206 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
trays
« on: 14 May 2009, 11:44:25 »
a question re- trays that are underneath miggy,s . does anybody know if the same tray fit,s all models.  vx locally didn,t know.  :)
NiallyV6CDX
  • County Down
Re: trays
« Reply #1 on: 14 May 2009, 13:31:54 »
The BMW 2.5TD engine might be different to the GM engined models as it is a straigh 6 and is a different shape to the others, other wise they are probably the same. And Vx SHOULD know, they have access that sort of info on their systems! ::)
Re: trays
« Reply #2 on: 14 May 2009, 13:37:55 »
According to the EPC there are 2 undertrays .. one is No Longer Supplied (NLS), the other lists all the PETROL enines but none of the oil-burners  :(
 18 SPLASHGUARD, ASSY., FRONT SIDEMEMBER (NLS.- USE 90573747 2 12 639)   -V1965205 (90529596) (2 12 636) 1
  19  SPLASHGUARD, ASSY., FRONT SIDEMEMBER 20SE, X20SE, X20XEV, Y22XE, Z22XE, X25XE, Y26SE, X30XE, Y32SE V1965206-  90573747 2 12 639 1
raywilb
    • Citroen C4 Cactus
Re: trays
« Reply #3 on: 14 May 2009, 15:52:54 »
seems i wont be able to use trays off a 3.6. never mind i shall take mine completely off, as they trail on the ground & theyr,e nacked.  :)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: trays
« Reply #4 on: 14 May 2009, 20:17:04 »
Where are you at?
I've got one here that came off mine - and it's staying off ...... !
