Author Topic: Locked in Parked position  (Read 1932 times)
kmason8282
  • Southend
« on: 15 May 2009, 20:08:51 »
Only recently I have found that when starting my car (1998 S Omega Elite Estate) the electronic 'system' will not release from Parked mode.   What I have to do is disengage the gear cover and release the yellow catch (left hand side of gear lever) to get the car into Driver/Reverse.
This has only started occurring during the past two weeks.  No history of issue similar prior, kinda has come out of the blue.
Has anyone got any pointers on this.
thx
Re: Locked in Parked position
« Reply #1 on: 15 May 2009, 20:13:53 »
thx
Brake light switch goosed. :y  :y  :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #2 on: 15 May 2009, 20:29:06 »
thx
Yep - sounds right, and not the first time I've heard this one.
Omegatoy
  • UK
« Reply #3 on: 15 May 2009, 20:30:22 »
damn beaten to it!! agreed!!! brake light switch or poss loose connection on it!!
« Reply #4 on: 15 May 2009, 20:31:02 »
thx
It's fun trying to get the bloody thing out of Park when you're at the lights & others behind are waiting ........  ::)  ::)  ::)  ::)
Got the T shirt on that one!  ;D  ;D  ;D
kmason8282
  • Southend
« Reply #5 on: 15 May 2009, 20:36:04 »
Just to add some more colour to the issue it only seems to occur when I  attempt to start the car.  I have not had the issue in transit (at traffic lights, etc).
This could be circumstantial but also this may assist in the ascertaining the root cause.
« Last Edit: 15 May 2009, 21:02:41 by kmason8282 »
« Reply #6 on: 15 May 2009, 20:44:39 »
........  I have not had the issue in transit.  ........
cos you're still in D ......  ;)  ;)  ;)
Brake switch is the usual cause, can't remember how much they aare, but they're not expensive & easy to fit.  :y
« Last Edit: 15 May 2009, 20:44:50 by Andy_B »
osealy
  • dublin
« Reply #7 on: 15 May 2009, 20:47:31 »
Mine does this as well.
But why would anyone use park, in transit.
« Reply #8 on: 15 May 2009, 20:49:48 »
When you're too bone idle to keep your foot on the brake at lights!! ........ apparently! ::) ::)
 :y ;D :y ;D :y
KillerWatt
« Reply #9 on: 15 May 2009, 20:52:27 »
 :y ;D :y ;D :y
If you're gonna be pedantic, you should be applying the handbrake and putting the car in to neutral at lights ;)
« Reply #10 on: 15 May 2009, 20:59:47 »
If you're going to be lazy you might as well do just one operation ie put it in Park. Applying the handbrake & putting into N is two!!!  ;)  ;)  ;) :y :y
osealy
  • dublin
« Reply #11 on: 15 May 2009, 21:03:13 »
Then if somebody does rear end you! You can claim 4K for a new slushbox.
KillerWatt
« Reply #12 on: 15 May 2009, 21:05:21 »
If you want to pass your test, you'll be applying the handbrake whether you select neutral or park ;) (selecting neutral is obviously quicker and less effort).
« Reply #13 on: 15 May 2009, 23:03:02 »
I passed my test 30 years ago! I now cross my hands when turning the wheel, hit kerbs when/if I do 3 point turn!  :-?
KillerWatt
« Reply #14 on: 16 May 2009, 01:27:23 »
29 years ago for me, although I tend to avoid kerb clipping and rarely cross my hands on the wheel (mainly because I drive one handed).
