Author Topic: self level fuse.  (Read 2748 times)
self level fuse.
« on: 15 May 2009, 18:53:38 »
Anyone know which number fuse for self level pump? Fitting Mv6 suspendees over the weekend and need to shut the pump up.
Cheers. :-)
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
He who brakes Looses
To old to die young
Re: self level fuse.
« Reply #2 on: 15 May 2009, 21:21:07 »
try if this helps you mate.
www.omegaowners.com/forum/YaBB.pl?num=1176560725
www.omegaowners.com/forum/YaBB.pl?num=1161602008 :y
Cheers Dave. Not seen those guides before. Beleive it or not :D
Ghost
    • 2.6 V6 CDX Estate
« Reply #3 on: 15 May 2009, 21:24:37 »
I snoop around a bit and you would be surprised what you can find. ;D
pleased I could help :y
To old to die young
kjf7
  • lincolnshire
« Reply #4 on: 15 May 2009, 23:14:33 »
how do you know if this is working or not (sorry not butting in as have been thinking about this while loading the old drum kit into car tonight) :y
« Last Edit: 15 May 2009, 23:16:02 by kjfomega »
Ghost
    • 2.6 V6 CDX Estate
« Reply #5 on: 15 May 2009, 23:32:12 »
How do we Know if whats working??
To old to die young
kjf7
  • lincolnshire
« Reply #6 on: 15 May 2009, 23:35:01 »
auto self leveling suspension mr friendship
« Reply #7 on: 15 May 2009, 23:36:04 »
Being a musician you wouldnt understand. But you might if dislexic with Alzhimers. :-)
« Reply #8 on: 15 May 2009, 23:36:09 »
You hear your compressor running a short time after you satrt the car ..... and then the back offf the car rises. ie it self levels!!  ;)  ;)  ;) :y
kjf7
  • lincolnshire
« Reply #9 on: 15 May 2009, 23:37:41 »
bloody cheek  >:(
kjf7
  • lincolnshire
« Reply #10 on: 15 May 2009, 23:41:21 »
not sure if mine does that i can hear what i thought might be the fuel pump could be wrong, if not could it be caked in crapo.
« Reply #11 on: 15 May 2009, 23:43:52 »
Compressor lives under the front driver's side wing/bumper. Also depends if a previous owner has been a tight arse & put ordinary dampers/shockers at the back, you should have thin plastic pipes going to the side of each of them.
Ghost
    • 2.6 V6 CDX Estate
« Reply #12 on: 15 May 2009, 23:46:59 »
If you turn the ignition on without starting you should hear the compressor/pump running, ( front of car ) if you have the correct shocks fitted ( unlike mine ) then when you load your car full you might feel a movement when you turn the ignition on.
To old to die young
kjf7
  • lincolnshire
« Reply #13 on: 15 May 2009, 23:48:10 »
well thanks andy b it's nice that you'rde not picking up on my spelling this evening
« Reply #14 on: 15 May 2009, 23:50:43 »
bloody cheek  >:(
Yes, seems i'm "at it again".
Pump sits behind front bumper drivers side and can be heard after start up, as Andy says. If you want to check further, load the car fully, then start the car and sit on the bumper/boot ledge, feet on the floor, you will feel the car rise. Also,if still unsure and  handy for working on/under the rear of the car, you can pop to rose joint off the level sensor box drivers side of dif. and raise the right angle arm to raise the rear of the car to a silly hight, engine running or the battery will go flat. Hth
