Author Topic: 3.0ltr elite water pump  (Read 3469 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« on: 30 April 2009, 21:54:28 »
Just got the wifes 2.2dti mig back and now i think the water pump bearing is going on my toy. only noticed last night when the wife came home as i was putting my other joy back in after work. how long does this take to do and whats the job like to do on the V6? >:(
RobseyMV6
  • west sussex
Re: 3.0ltr elite water pump
« Reply #1 on: 30 April 2009, 21:58:03 »
Fairly easy as not on timing belt like the 2.0 and 2.2
« Last Edit: 30 April 2009, 21:58:16 by RobseyMV6 »
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #2 on: 30 April 2009, 22:31:05 »
if you buy the cambelt dvd from the oof shop it covers water pump change as well :y
basically though:
remove multiram (bagpipes)
loosen water pump pulley bolts (easiest with belt still on)
loosen aux belt tensioner (15mm socket clockwise to loosen)
slip aux belt off
remove water pump pulley
change water pump (3 x torx bolts)
and in the famous words "reasembly is reverse of removal" :y
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #3 on: 01 May 2009, 20:48:25 »
Thanks for that. I phoned the main dealer today and they want £131.10 for the pump and the auto factors want £41.39 so were do you think i should go
MutantCav
  • Gainsborough
« Reply #4 on: 01 May 2009, 20:53:39 »
Gen water pump from Vaux is only about £25 on TC...might be worth asking a local member with TC to help you out if you dont have one yourself??
Bent valve
« Reply #5 on: 01 May 2009, 20:54:59 »
£131.10 ! ;D ;D ;D ;D try AUTOVAUX on tinternet about 15 quid for an OE manufactured one with a steel impeller
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #6 on: 01 May 2009, 20:58:10 »
so thats why they asked me on the phone if i was trade or not!! :-? so any TC holders near swindon wilts who can help please :) :)
MutantCav
  • Gainsborough
« Reply #7 on: 01 May 2009, 21:01:11 »
I can buy one from and send it to you for £100?? lol
Yeah on some items it makes a staggering difference having a TC...well worth spending the £20 a year joining ABS and getting a card :y
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #8 on: 01 May 2009, 21:11:12 »
i think i will pass on that thanks. Ijust looked on autovaux and it said £26.95 so i thank you all i just saved over £100 and can now fill the tank again :) :) :) :)
MutantCav
  • Gainsborough
« Reply #9 on: 01 May 2009, 21:13:25 »
Was only kidding mate :y
Best bet though if replacing the pump is not 100% urgent is to join ABS tonight...should have your card within a couple of weeks max and get the pump on your own TC then :y Worth ringing back the stealers tomorrow and get a price on TC and be prepared to be staggered :y
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #10 on: 01 May 2009, 21:18:37 »
I will do that thanks. what the full name of place to go to :y
Bumbazor
  • Worksop
« Reply #11 on: 01 May 2009, 21:25:39 »
MutantCav
  • Gainsborough
« Reply #12 on: 01 May 2009, 21:27:49 »
Phew...saved me trying to spell it lol
The guy that runs it is called Alf and seems to be a very nice chap :y
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #13 on: 01 May 2009, 21:32:46 »
thanks willsort that out when i get home from work tomorrow :y :y
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #14 on: 01 May 2009, 22:01:17 »
you can get a TradeCard if your a legitimate VAT registered buisness lots of proofs required!!
and it costs nothing!
