Author Topic: Oily intake  (Read 1893 times)
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Oily intake
« on: 16 May 2009, 18:51:31 »
Cleaned the breathers, throttle body and changed the oil and filter today.
Breathers were fairly clean as it is about a year since I did them last.
Throttle body cleaned up easily with a bit of gunge in the little pin hole.
I noticed that with throttle body removed that the inside of the intake manifold had a film of oil all around it..........is this normal?
« Last Edit: 16 May 2009, 19:03:26 by alexandjen »
Trade club card holder
Code scanner available
Omega man 2
Re: Oily intake
« Reply #1 on: 16 May 2009, 19:01:20 »
Normal on the two 4 pots that we had :-/
HGV mechanic
  • northamptonshire
  • he just keeps on going,,,
Re: Oily intake
« Reply #2 on: 16 May 2009, 19:27:41 »
a film is nothing to worry about,normally from the EGR system, its when pools gathering you need to consider action
« Last Edit: 16 May 2009, 19:28:30 by matthew »
alexandjen
  • The Silver Surfer
Re: Oily intake
« Reply #3 on: 16 May 2009, 19:31:39 »
Thanks for that :y
Would this point to EGR needing a clean?
HGV mechanic
  • northamptonshire
Re: Oily intake
« Reply #4 on: 16 May 2009, 19:41:45 »
Thanks for that :y
wouldent hurt but i dout it make much of a difference
big-o-bob
  • Yorkshire
Re: Oily intake
« Reply #5 on: 16 May 2009, 19:52:18 »
When I removed the plenum on my V6, I noticed evidence of oil/petrol around the o'rings and down the lower manifold ports.
Is this normal?  It's just, I can't remember seeing it on my previous V6.....could be wrong though! :y
Abiton
Re: Oily intake
« Reply #6 on: 16 May 2009, 19:59:20 »
There was a fair old pool in the bottom of ours, the first time I cleaned TB/jet etc.  Bit of rag taped to a long stick was the method of choice as I recall, for removal.  Can't see it really going anywhere from there though?
Surely it all comes from the breather system, not the EGR?
