Author Topic: Headlight washer relay  (Read 1057 times)
Bumbazor
  • Worksop
« on: 16 May 2009, 17:27:36 »
I've found the fuse for the headlight washers, but where is the relay? Under steering wheel or next to battery? Which one is it?
Haynes doesn't mention specific relay locations, neither does owners manual.
Also, what type is it?
Thanks
Bumbazor
  • Worksop
Re: Headlight washer relay
« Reply #1 on: 16 May 2009, 19:54:54 »
I found it eventually; or rather, where it should be! Socket 2 in the engine relay box. Does anyone know what type of relay it is, or better still does anyone have one they would like to swap for some money?
unlucky mark mv6
  • tipton,west mids
« Reply #2 on: 16 May 2009, 20:15:36 »
Got shite loads of relays in the shed mate off various vauxhalls,dont know if any one of them will fit.Send me some numbers off it and i will have a look mate. :y
Bumbazor
  • Worksop
« Reply #3 on: 16 May 2009, 20:27:15 »
The problem is I have retro fitted headlight washers so I don't have a relay to compare with, but going on the colour of the socket, it is probably black. I don't have any other black relays that fit to compare with.
Agemo
  • Cleethorpes
  • Insignia
« Reply #4 on: 16 May 2009, 22:44:38 »
"Socket 2" - Are they numbered? Let us have a description i.e. Nearest Offside Rear or whatever.   :y
Bumbazor
  • Worksop
« Reply #5 on: 17 May 2009, 07:11:04 »
Yes they are numbered. And like I said its in the engine relay box and it is probably black.
