Author Topic: self Levelling Headlight Sensor  (Read 1480 times)
3.0V6Elite
  • Salisbury
« on: 17 May 2009, 15:00:13 »
I have the fault message on the dash display 'Low Beam Fld / Vision', which has been there since I had the car and was there for some time with my dad who was the previous owner.
Now I know that this is a problem with the sensors and motors for the self levelling headlights that are located at the front and rear of the car. I have checked and regreased the front sensor/motor and all seems fine there, but when I checked the rear one the 3 pin connector to the sensor was disconnected, so has probably been like that for years getting all kinds of s**t in both the male and female ends and seems to be past it. Is there an easy fix for this or will I have to replace the whole rear unit?
Re: self Levelling Headlight Sensor
« Reply #1 on: 17 May 2009, 15:30:39 »
got to be worth cleaning out the connectors and plugging in. See what you got and in from there?
3.0V6Elite
  • Salisbury
« Reply #2 on: 17 May 2009, 15:31:59 »
Already tried that mate, no luck.  :'(
« Reply #3 on: 17 May 2009, 15:35:50 »
not sure where you would source the plug, breakers? but the sensor itself is 50 quid with the connecting rod i beleive.
Richard A
  • Aldridge, West Midlands
« Reply #4 on: 17 May 2009, 15:41:39 »
First test the 'sensor' by putting power to a connector or use a multimeter, if no response, request secondhand unit on the 'parts wanted' area.
regards
richarda
richard a
