Author Topic: Help  (Read 1385 times)
DaviesEB
  • Monrovia Liberia
Help
« on: 18 May 2009, 16:53:03 »
Hope the weekend was great for all. I did a paperclip test and had 19. I had a cranksensor problem some time back.
Now i am having a misfire the miggy does not pull as before. Are my plugs bad or the cables faulty.
Used Opel Kadett 1.6 and refurbishing Opel Rekord 2.0
Dazzler
  • Haverhill, Suffolk
Re: Help
« Reply #1 on: 18 May 2009, 16:54:29 »
Code 19 is failed crank sensor. Did you fit a genuine one before??
DaviesEB
  • Monrovia Liberia
Re: Help
« Reply #2 on: 18 May 2009, 17:00:59 »
Yes i did with genuine part from Pentagon Vauxhall. I am wondering if it is the old code that is showing.
But i am starting the vehicle alright. My mech says i shold chnage crankseal. As there is an oil leak. He also suggets changing the timing belt. But i do not take his advice until i have contacted the Brains on the Forum.
Advice
Dazzler
Re: Help
« Reply #3 on: 18 May 2009, 17:05:08 »
Cambelt kit is every 40k without fail.
If you have an oil leak its best to get it fixed imho ;)
If you have oil leaking onto the sensor or its wiring then this could have caused it to fail early.
The old code would have gone by now, how long ago was it fitted?
DaviesEB
  • Monrovia Liberia
Re: Help
« Reply #4 on: 18 May 2009, 17:08:54 »
About three months ago. How easy is it to do cambelt kit. How much does it cost. Can i get same from Pentagon??? I am in love with my Miggy and would not want it packed. It has done 162K and the only thing done was to change Oil, filter and Crank Sensor.
Re: Help
« Reply #5 on: 18 May 2009, 17:15:18 »
I should clarify, as I suspect the OP runs in kilometres, that it is 40,000 miles, not 40,000 km :)
Dazzler
Re: Help
« Reply #6 on: 18 May 2009, 17:24:00 »
You can get a how to DVD from the forum which shows you how to change the cambelt kit, you will need a locking kit to do this job.
DaviesEB
  • Monrovia Liberia
Re: Help
« Reply #7 on: 18 May 2009, 17:27:25 »
How much does the locking kit cost. Also the dvd. So i can plan to have same bought.
Dazzler
Re: Help
« Reply #8 on: 18 May 2009, 17:55:07 »
DVD about £5ish
Locking kit is about £80
Cambelt kit about £90
DaviesEB
  • Monrovia Liberia
Re: Help
« Reply #9 on: 18 May 2009, 17:57:48 »
where do i buy em from M8?
Re: Help
« Reply #10 on: 18 May 2009, 18:30:15 »
Really?  Check the OP's location ;)
Dazzler
Re: Help
« Reply #11 on: 18 May 2009, 18:56:46 »
:-[ sorry, didnt realise  :(
